SkIndigo 3.0.15 (beta)
Re: SkIndigo 3.0.15 (beta)
Post by Whaat » Thu Aug 18, 2011 8:04 am
davidbaird wrote:2 licenses both version 3.0.14
1 on windows xp 64bit
1 on windows 7 64bit
both work with Skindigo 3.0.14 but not 3.0.15
Thanks
Can you please post the .PIGS file as well?
1) Go to SkIndigo->Export Scene As...
2) Open the IGS file in Indigo
3) Save Scene as... (and then choose a .PIGS file)
4) Upload to forums.
Frutiger
Post by Frutiger » Thu Aug 18, 2011 9:48 am
I seem to be having issues with environment maps. Here's the error message.
Error: Scene parsing error: Error while binding material 'Environment Map' to geometry 'Group#55': No such material defined 'Environment Map'
Post by Whaat » Fri Aug 19, 2011 3:25 am
Frutiger wrote:I seem to be having issues with environment maps. Here's the error message.
Do you have a material named 'Environment Map' in your model?
Are you trying to use this material as an environment map? Can you describe the steps you took? Were you trying to render an old file (created before SkIndigo 3.0.15 was released?
davidbaird
Post by davidbaird » Fri Aug 19, 2011 5:00 am
Thanks
I tried the following-
After pressing the render button in SU, the black Indigo screen comes up & the error message appears immediately. The scene never gets built & starts to render. I went back to SU & exported the scene as igs.
Then I tried to render the igs in Indigo. It does not open either & I get the same result as above.
I also uninstalled Indigo & Skindigo & reinstalled both & got the same result as previously (.14 works & .15 does not)
I have attached partial contents of the error report...I don't have a clue what it means!
Thank you
partial contents of error report
Post by Whaat » Fri Aug 19, 2011 7:55 am
Thanks
Thank you
Can you please find the two .igs files that were exported by Skindigo and attach them as a zip file to this thread? You should have a name.igs and name-meshes.igs.
Thanks for your patience.
davidbaird
Post by davidbaird » Fri Aug 19, 2011 12:23 pm
the following are in the zip file:
.igs
meshes-igs
indigo_path.txt
log.txt
thank you
indigo.zip
(2.43 KiB) Downloaded 320 times
Frutiger
Post by Frutiger » Sat Aug 20, 2011 5:32 am
Sorry for the delay. Thought I'd responded already!
I followed the steps you posted a little earlier.
1. Create new material.
2. Apply .exr file as the emitting texture
3. Change render settings to use texture as environment map
However, this is a file that was created before 3.0.15 so I'm going to copy all the geometry over and start anew.
Post by Whaat » Sun Aug 21, 2011 3:35 pm
OK, this is a bug. It will be fixed in the next update
Xaon
Post by Xaon » Tue Aug 30, 2011 3:07 pm
Salut,
j'avais déjà posté une demande d'aide sans succès... :roll:
Je rencontre un soucis avec Skindigo depuis mon passage à la version 64 bits de Windows 7.
En effet, il ne m'es plus possible de lancer un rendu via le bouton dans Sketchup; il ne se passe rien. Sketchup et Indigo sont installés dans leurs répertoires respectifs (par défaut, donc).
Pourtant, lorsque je déplace le dossier dans lequel est installé Indigo (peut importe l'endroit sur le disque dur), un message s'affiche :
J'utilise la version gratuite de Sketchup... Je ne sais plus quoi faire.... :|
Post by Whaat » Sun Sep 04, 2011 4:42 pm
davidbaird wrote:the following are in the zip file:
.igs
meshes-igs
indigo_path.txt
log.txt
thank you
Hi David,
Could you try using SkIndigo 3.0.15 but make sure you turn off GPU in the SkIndigo render settings?
Thanks
Post by Pibuz » Sun Sep 11, 2011 11:40 pm
Hi Whaat! I'm curious about one thing.
I'm about to createa small network with my two pc at home. I wonde how external meshes are handled in network rendering: since only the path is exported and not the actual geometry, how will slave recognize the path to the master (given that the master is the pc on which I've built the scene)?
Post by Whaat » Tue Sep 13, 2011 4:47 pm
Pibuz wrote:Hi Whaat! I'm curious about one thing.
Hey Pibuz,
Do you know how to map a network drive? If you map a drive letter to a network folder that is accessible by both the master and the slave, then I believe both fill be able to find the external mesh.
Actually, it may not even matter because I think when Indigo sends the scene over to the master, it packs up the external mesh with the rest of the scene in the .PIGS file so you might not have to worry about this at all. :)
Post by Pibuz » Tue Sep 13, 2011 7:25 pm
I ask because I recently worked with Packed scenes (to transfer a render from 32bits windows to 64bits Linux) and the igs only showed the path, not the mesh. Don't know if the network rendring process is different..
BTW, Snorky as sent me an useful guide to map hard drives so I think I will follow that, in the worst of the cases! I'll let you guys know, thanks!
rayrender
Post by rayrender » Thu Oct 06, 2011 5:20 pm
Hey Whaat,
Thanks for this great work. Now I can make cool Outdoor-Scenes with Sun and Clouds, Great.
But I have little problem with the light-settings. When I create a Group, like a Lamp, and copy them, the first Group dosent light so bright as the other. So I copy them and the first light I move into the wall or behind the camera :)
It's also realy hard to get the right settings between sky illumination, sun and lights.
first light is not so bright.
Win7 64bit; AMD X6 1090T 3.2 GHz; 16GB RAM; Nvidia GT260
Sketchup 8.0.4811; SkIndigo 3.0.15; Indigo 3.0.14
http://www.rayrender.de
Matteo
Post by Matteo » Thu Oct 06, 2011 10:55 pm
How do I create an image of exr on sketchup?
