Light dots on my planes - where do they come from?
7 posts • Page 1 of 1
Jardar
Post by Jardar » Fri Jul 22, 2011 1:35 am
Hi, guys!
I'm redoing this scene in Sketchup just for getting used to Indigo. The problem is mostly with the grey wall. At first, it looks 100% grey, but after rendering for some 5 minutes I start to get light brown dots all over the wall (and on the chairs too). What do they stem from? Is it reflections from something?
Some info on the materials if they help:
The wall and ceiling - 95% diffuse/phong blend with the same albedo. Diffuse has a slight bump (0,3 mm), phong has smoothness 50, IOR 1.33
The floor and the plywood wall - phong, smoothness 912, IOR 1.196
The door and frames - phong, smoothness 300, IOR 1.33
The chairs - phong, this material (http://www.indigorenderer.com/materials/materials/246)
The rest of the walls are Exit Portals.
dcm
Re: Light dots on my planes - where do they come from?
Post by dcm » Fri Jul 22, 2011 2:17 am
use pathtracing not MLT
Post by Headroom » Fri Jul 22, 2011 2:21 am
Those are reflections or "color bleeding".
Let it cook for for an hour (or a few hours) and the "spotty" appearance should disappear.
Jardar
Post by Jardar » Fri Jul 22, 2011 3:03 am
With path tracing (the first attempt was with MLT):
It looked good till about 30 minutes in, then fireflies started appearing. Is this the same as color bleeding?
Post by StompinTom » Fri Jul 22, 2011 3:57 am
With Pathtracing, it starts to sample caustic effects and reflections, but it sucks at it, so you end up with little specks that take ages to resolve, if they ever do. I'd suggest BiDir + MLT and let it cook. The brown splotches are probably caustic reflections from the floor or walls.
Jardar
Post by Jardar » Fri Jul 22, 2011 3:58 am
Bidirectional Path Tracing seems to do the trick! 51 minutes, 340 spp. :D
dcm
Post by dcm » Sun Jul 24, 2011 9:46 pm
if you want to get rid of fireflies, use higher Supersampling value (im uising 4 every time)
