Error: Scene parsing error
Hey there, i got a problem with exporting/render the scene from sketchup.
don't know what to do. theres a window telling me this:
Error: Scene parsing error: num_values must be >= 2. (In element 'regular_tabulated', around line 275, column 21)
thanks for any help
thanks for any help
Re: Error: Scene parsing error
hi i have the same problem
Except mine says line 535 column 21.
How do i fix this?
How do i fix this?
Did you import any particular IGM materials into your SketchUp file? If so, which one?Emma wrote:hi i have the same problem
How do i fix this?
Im not sure what igm materials are? i imported a .3ds vectorworks file into sketchup.
HI,
Error: Scene parsing error: failed to load XML doc from path 'D:/Data/sketchup/wellness centre/render/render bestanden/vooraanzicht 2.igs': Error reading end tag. (Line 1318, column 1.)
If i'm right, an IGM material is a material from the indigo website ??
if that's so, i did'nt import it to my model. all the materials i have in my model are sketchup materials and .jpeg
how can i find out if i have IGM materials in my model?
i did try to render a selection, bud it did'nt matter what selection i try to render, nothing works, the only difference is the line and column number.
so PLEASE HELP
so PLEASE HELP
External Indigo Material Files/descriptions. Everything that comes from the Indigo material database (online) comes in form of an IGM or PICM (Packed Indigo Material).
Emma and Franky,
Please post the SKP file (zipped) so I can test it. Thanks.
hey,
here is my zipped SKP file,
hope you can find the problem
try again. missing filefranky wrote:hey,
hey thanks for the help, i think it was the glass i was using, i have it working now using thin glass and its all working!
hey whaat,
i tryed to send the model, bud i think it's to big, can i send it to you an other way?
I have it running again
I think it was a three, bud i'm not shore what the problem was exactly.
tanx any way
frank
tanx any way
frank
