Frosted Glass Material Problem!
12 posts • Page 1 of 1
black_snow
Post by black_snow » Thu Jul 14, 2011 5:28 pm
I'm running SKIndigo 2.6.1 on WIndw 7 64 bit , I7-920 , 12 GB Ram , GTX 580 Graphic Card.
for this simple kitchen rendering , it takes about 9 hour but only have a result like this.
whats the problem with the frosted glass material still so much noise ?
is that any way to settle the above problem ?
Rendering time 9 hours
Meelis
Re: Frosted Glass Material Problem!
Post by Meelis » Thu Jul 14, 2011 5:44 pm
Will, it get cleaner with MLT & BiDir in same time :roll:
Did u use exit portals?
black_snow
Post by black_snow » Thu Jul 14, 2011 8:48 pm
yes, i did use exit portal for the window ..
im using Birdir with Architectural Glass Acceleration
galinette
Post by galinette » Thu Jul 14, 2011 11:41 pm
Did you use MLT?
Also try without glass acceleration. It can help only for flat specular glass (such as the window) and not for frosted. Also, I'm not sure it is useful for indoor scenes with portals.
Etienne
Eclat-Digital Research
http://www.eclat-digital.com
Post by Pibuz » Fri Jul 15, 2011 5:07 am
Probably your whites are too white, and you're not using MLT.
Post by lycium » Tue Jul 19, 2011 5:31 am
Glass acceleration doesn't work well with exit portals currently :( However, when you're using exit portals it's anyway more efficient than GA would be.
Etienne's advice is spot on: try without glass acceleration (but still using bidir and maybe also without MLT).
black_snow
Post by black_snow » Thu Jul 21, 2011 4:21 am
here is the final result for the MLT setting render.
Post by Pibuz » Thu Jul 21, 2011 4:28 am
BiDir MLT or MLT+PT?
BTW, quite good result! Good job!
..only thing, I see too many sharp corners... SMOOTH SMOOTH SMOOTH!
Post by StompinTom » Thu Jul 21, 2011 4:37 am
Very nice :) Love the tones.
If you'd square out the composition and add accessories and some more 'lived-in' detail, it'd be a great shot!
Post by Headroom » Thu Jul 21, 2011 4:52 am
Good advice here. I'd also change the texture mapping on the large wooden frame in the right part of the image. The texture should run vertically on the vertical parts and horizontally on the horizontal parts (not sure I explained that well).
black_snow
Post by black_snow » Thu Jul 21, 2011 3:04 pm
Pibuz wrote:BiDir MLT or MLT+PT?
Sorry pibuz.. the reason i let the model square edge is because i need to do another details works with LayOut
that's why .. if i use the soften i cant get the edge point in LayOut.
or you got a better idea for me ? :|
i hate details works!!!!
Post by Pibuz » Thu Jul 21, 2011 7:27 pm
I didn't mean "soften edges" :lol:
I meant: use some cool plugin like roundcorner.rb to get less sharp 3D edges: they will result much better in the rendering..
..Though, you still may not see them in layout.. :?
