"Errors occurred while attempting to unpack the PIGM file."
Come here for help & support.
7 posts • Page 1 of 1
Coen Naninck
Post by Coen Naninck » Tue Jun 28, 2011 12:55 am
I get this error when trying to load a new material from the online repository. I found this thread, but no solution there. And then it says "Material could not be loaded.".
I installed SkIndigo exporter over the old version (which was not installed but contained in the SketchUp Plugins folder which I simply copy and paste when reinstalling Windows). Maybe this has something to do with it?
By the way I bought my RT license last Friday and emailed support if the payment went well but haven't received a response yet. Maybe that's due to the weekend?
Coen Naninck
Re: "Errors occurred while attempting to unpack the PIGM fil
Post by Coen Naninck » Wed Jun 29, 2011 8:01 am
Does anyone from Indigo Support know about this issue? I basically can't load new materials now.
Post by OnoSendai » Wed Jun 29, 2011 9:00 am
Hi Coen,
I think this issue is due to the RT build not including the console, which is used for material unpacking.
We will fix this issue soon with a new build.
Coen Naninck
Post by Coen Naninck » Wed Jun 29, 2011 9:23 am
Post by Whaat » Thu Jun 30, 2011 2:29 am
OnoSendai wrote:Hi Coen,
Yes, I am sure that is the problem. For a temporary workaround until the new build is out, you can do the following:
1) Download an Indigo material using your Internet browser.
2) In the Indigo GUI, use the Tools->Unpack Indigo Scene or Material and select the file you downloaded
3) Once unpacked as a file with an IGM extension, SkIndigo should be able import it no problem.
Coen Naninck
Post by Coen Naninck » Thu Jun 30, 2011 2:58 am
Thanks Whaat!
d.eder
Post by d.eder » Tue Dec 20, 2011 7:21 pm
Hey!
I tried what whaat suggested but no success. attempting to unpack the pigm using the indigo gui i get this:
Error: An error occurred while unpacking the packed Indigo scene or material: Failed to open zip file at '.....path...../Parkett.pigm'.
about a year ago i could just unpack the pigm using stuffit expander but that seems not to be possible anymore.
any advice? thanks
Indigo Renderer v3.0.14, OS X 64-bit build
Mac OS X 10.7.2
