Maxigo 3.0.7
Maxigo 3.0.7
Post by suvakas » Thu Jun 16, 2011 11:29 pm
Hey all,
This is the last Maxigo version that uses maxscript. Next Maxigo will be a proper plugin.
It still has this nasty "crash on load" bug which I wasn't able to track down. I wasn't sure if I should upload this version or not. But I'm still uploading it so you can have something to play with that is more compatible with Indigo 3.x
Changes in v.3.0.7:
* changed - Aperture shape default values under Camera parameters
* changed -  UV sets now use index instead of name
* added - Smoothing option for bump, displacement, opacity and glossiness maps
* added - A, B, C and Gamma parameters for all texture maps of IndigoMain material
* added - Medium to FastSSS material (better SSS effect)
* added - Vignetting option to Camera parameters
* added - Material ID tracer mode to Export scene rollup (renders every material with a different solid colour)
* removed - Frame upload period from Network rendering rollup
Suv
Maxigo_3.0.7.zip
(3.71 MiB) Downloaded 7229 times
dcm
Re: Maxigo 3.0.7
Post by dcm » Thu Jun 16, 2011 11:48 pm
suvakas wrote:Hey all,
* removed - Frame upload period from Network rendering rollup[/code]
Suv
why ?
Re: Maxigo 3.0.7
Post by fused » Thu Jun 16, 2011 11:52 pm
Suv
why ?
Because Indigo now automatically chooses the frame upload period. Its a bit like the tone mapping cycle, but has a maximum value of 20 minutes.
Cheers!
dcm
Re: Maxigo 3.0.7
Post by dcm » Thu Jun 16, 2011 11:53 pm
what is default value ? i was using 1 minute for my scenes to have quick update...
Re: Maxigo 3.0.7
Post by OnoSendai » Thu Jun 16, 2011 11:58 pm
dcm wrote:what is default value ? i was using 1 minute for my scenes to have quick update...
It starts off at a few seconds and slowly increases to 20 mins.
dcm
Re: Maxigo 3.0.7
Post by dcm » Fri Jun 17, 2011 12:07 am
thanks for info Master
dcm
Re: Maxigo 3.0.7
Post by dcm » Fri Jun 17, 2011 12:55 am
i tried to import older material (black glass)
dcm
Re: Maxigo 3.0.7
Post by dcm » Fri Jun 17, 2011 1:29 am
pls 0,333/0,333 as default for dwnsize filter
dcm
Re: Maxigo 3.0.7
Post by dcm » Wed Jul 20, 2011 9:05 am
can u add new filter(s) to 3.0.7 pls ? Sharp etc.
e3D
Re: Maxigo 3.0.7
Post by e3D » Wed Oct 12, 2011 4:07 am
I was just wondering if there is likely to be an update for the plugin soon?
The crash on load is a bit of a pain.
Thanks
ZYX
Re: Maxigo 3.0.7
Post by ZYX » Thu Dec 29, 2011 3:35 pm
I'm, having an error when exporting any scene. When I click 'export' the bar just fills up like every time but indigo doesn't start and the file is not exported. I'm using 3ds max design 2012. Could you give me any advice?
Thanks.
ninopiamonte
Re: Maxigo 3.0.7
Post by ninopiamonte » Tue Apr 17, 2012 7:07 pm
ZYX wrote:Hi,
Thanks.
I'm also having that problem. That was really my first attempt to try with 3ds Max 2012, then Indigo.
I need help :D
Re: Maxigo 3.0.7
Post by suvakas » Tue Apr 17, 2012 7:40 pm
Yep, it's broken and unusable for Max versions > 2011.
Autodesk changed smth in maxscript implementation and Maxigo code doesn't run as it used to run in older versions.
tar_gniK
3D Software: 3ds Max
Re: Maxigo 3.0.7
Post by tar_gniK » Tue Apr 17, 2012 8:09 pm
Are you sure it is "broken and unusable"? I use Maxigo 3.0.7 with Indigo 3.2.10 on Max 2012 and I have no problems at all -- apart from the bug where if you render a file, you must close Max completely if you want to open a new file -- I just open a new instance of Max instead. :roll:
Re: Maxigo 3.0.7
Post by suvakas » Tue Apr 17, 2012 8:11 pm
Ok, it's not completely unusable, but yes, it crashes :)
Users browsing this forum: No registered users and 126 guests
