Blendigo (for Blender 2.4x) 3.0.10
3.0.10
DOWNLOADS
WINDOWS: http://www.indigorenderer.com/dist/expo ... taller.exe
LINUX: http://www.indigorenderer.com/dist/expo ... .10.tar.gz
OSX: http://www.indigorenderer.com/dist/expo ... 3.0.10.zip
New in this release:
* GPU rendering mode switch
* Vignetting camera settings
* Fixed auto_chose_num_threads vs. num_threads logic
* Add texture smoothing switch for bump, exponent, plend and displace
* Chagne UV Tex name input to UV Tex index number
* Add MaterialID render mode
YOUR FEEDBACK IS ALWAYS APPRECIATED
As with the current efforts to get Indigo 3.0 as complete and user-friendly as possible,
please please keep reporting any issues you find with Blendigo - it is your feedback as
users and artists alone that push Blendigo forward into being the software that works for you.
DOWNLOADS
Re: Blendigo (for Blender 2.4x) 3.0.10
Is anyone using this exporter ?
Trying it out right now, actually. Motionblur works great!dougal2 wrote:Is anyone using this exporter ?
GPU switch doesn't really work proper... If it's disabled, and I was using GPU accel. in a previous render, it will still be on.
Still have to try with particles and such...
FakeShamus
would like to try it out - Mac version?
Yeah, I noticed that too, and already told Yves about it.StompinTom wrote:GPU switch doesn't really work proper... If it's disabled, and I was using GPU accel. in a previous render, it will still be on.
We discussed it in the office and decided to change the priority for that setting. Scene setting > Registry.dougal2 wrote:Yeah, I noticed that too, and already told Yves about it.StompinTom wrote:GPU switch doesn't really work proper... If it's disabled, and I was using GPU accel. in a previous render, it will still be on.
Will be in the next version.
You need to have Python 2.6 installed for it to work.
"No installed Python found."
I've just uploaded the linux and osx versions; sorry for the delay.
FakeShamus
I found this - when I try to click on the the 'exponent' section under a material I get a python error:
this is with the Mac version.
File "/Applications/Blender/PythonScripts/blendigo.py", line 1582, in materialGUI
IndigoUIControls.Materials.matExponentUVset = Blender.Draw.number("", IndigoEvents.evtNoEvt, gui.x, gui.y, 95, 18, IndigoUIControls.Materials.matExponentUVset.val, 0, 8, "exponent texture UV-set index")
AttributeError: 'module' object has no attribute 'number'
Oops, that's a little typo, should be easy to fix.
FakeShamus
cool-
there's one other thing I had noticed in previous versions too, the camera response functions don't show up in the Mac version under camera tonemapping. however that pathname is set doesn't work. I fixed it by putting in the absolute path to the folder in the Blendigo.py.
Hello, I have tried the new Blendigo for Blender (2.49b x64 - on Windows 7x64) and new Indigo 3.0 with a simple scene showing a gold bracelet with diamonds, and an emerald on a wood surface, lit by 3 emitting planes. It worked fine.
After that, I tried to export a huge city scene with high poly buildings and 5 detailed cars I had so far rendered with Octane. I'm trying in indigo, because I run out of memory in Octane.
I have 882 objects, one sun lamp and a camera.
All objects have materials, but I have not adjusted them because I want to do all settings in indigo, as I did with Octane.
Usually, a lamp object has no UV layer in Blender, so I dont understand the error !
I encounter a weird error in the export process :
@ROUBAL
Are you sure it's not a mesh object called "Blender Lamp" ? Can you strip down the file to just that object and post it here so that I can examine it ?
I have created a new empty Blend file, and using the append function, I have looked in detail to the objects and mesh list, and I confirm that there is no object called Blender Lamp, as well as no lamp other than one unique sun lamp.
I even opened the blend file with notepad++ and searched the words "Blender Lamp" without success...
Currently I'm trying to delete objects and exporting by parts, but I can't find out where is the trouble.
After deleting half of the objects, I encounter the same message for Blender Camera object !
But a Camera has no UV Layer as well and the only present camera is named camera ! Very weird
bug !
I also deleted all objects with an emit factor, in case they would be renamed as lamps by Blendigo (even if I have chosen Physical Sun +Sky as lighting method).
And this gives a different error message (that could be a clue ?) that you can see below :
bug !
