Marble tiles
Marble tiles
Post by CTZn » Mon May 16, 2011 2:05 am
It will be one single phong material, using ISL for its albedo, bump and exponent.
I am already nearly done with the albedo: I would like to increase the randomness in tones distribution (currently dark and light tiles are grouped, depends on tiles frequency though), and add variance in the cement.
It will be easy for the user to customize the reference marble texture (a bitmap currently, wich is scanned over its two dimensions) and the number of tiles, horizontally and vertically. In effect, tiles don't have to be square.
Note that the result will be procedural, wich means that no texels will be visible no matter how close the shot will be.
Thanks to robostimpy for its artwork, and for encouraging us to make our own marble. That may be the matter for another ISL development thread, though not a simple one obviously (I'm reserving myself the right to fly away from that one :mrgreen: ).
Concerning an introduction to ISL, I mean to make it a brand different topic, to start with the basics (I just acquired).
reference pic:
http://robostimpy.deviantart.com/art/Marble-21-402-188757389
Current albedo below
Re: Marble tiles
Post by CTZn » Mon May 16, 2011 2:38 am
Below is the reference I used to discretize the fbm's:
http://www.digitalartform.com/archives/ ... tiled.html
Wich gives, under a rather expanded ISL form (and as used in the albedo above):
	def slicesU() real : 16.0
	def slicesV() real : 24.0
	def discreteU() real :
		div(floor(mul(texi(), slicesU())), slicesU())
	def discreteV() real :
		div(floor(mul(texj(), slicesV())), slicesV())
	def outUV() vec2 :
		vec2(	discreteU() + u(),
				discreteV() + v()	)
	def marbleTiled() vec3 :
		sample2DTextureVec3(0, outUV())
NB: this code chunk is not functional alone, notably u() and v() are defined otherwhere.
Re: Marble tiles
Post by suvakas » Mon May 16, 2011 3:15 am
Just awesome!
So CTZn, you got into ISL ? Very cool. 8)
galinette
Re: Marble tiles
Post by galinette » Mon May 16, 2011 3:37 am
If interested, I can make a marble texture to my procedural ceramic:
http://www.indigorenderer.com/materials/materials/286
That way, you will have the full randomized procedural bump + tile misplacement (tiles are procedurally not perfectly aligned, which improves a lot realism)
Eclat-Digital Research
http://www.eclat-digital.com
FoXar
Re: Marble tiles
Post by FoXar » Mon May 16, 2011 3:55 am
Very interesting, I'll make sure to follow this topic! It's great to see what Indigo can do with procedural coded materials, it's quite unfortunate that it ain't simple..
Cheers,
Roo Evans
Re: Marble tiles
Post by CTZn » Mon May 16, 2011 6:44 am
We are of course, goodies, always !
As far as I'm concerned I want to keep understanding what I am doing or I wouldn't learn; I'm not getting your advanced code out of the box for the least (my math teachers all hated me, now I'm understanding it's because it was insulting that I couldn't understand their art. If some numbers ain't real then none are coz they're all numbers now let me alone ! I was ok at logic tho ;)), but yes I'll check closer at some point. I have that chance that marble is often of a straight cut (with a tiny, straight, 45° bevel tbh).
In the other hand Etienne I am interested in discussing you modelisation methods (I mean, in plain english to start with), I think you are able to place and orient each tile individually as you please while mines are only shaped by a straight grid. Did you start with pyramids ?
The most complicated thing I'll have to do for the current material will be to fit a flattish sinusoidal carving along the cement lines, I know I'll use the min() function to merge horizontal and vertical bands already. No joke I'll have to find the correlation out... please lemme do this ! But also Etienne, please do here as fun drives you !
Suvakas: yup thank you, and congrats about the new maxigo !
Re: Marble tiles
Post by CTZn » Wed May 18, 2011 12:45 am
I'm currently trying to have more control on the shader, more pics tonight. Also I recon that the lack of a slope over tiles borders is not that great on bump mapping by a close shot, not sure what I can do myself about that.
Anyhow I'll have the material posted this week, I'd rather not be so perfectionist for a first try.
Oh and sorry about what I said on my maths teachers, they couldn't help that's all :twisted:
Re: Marble tiles
Post by CTZn » Wed May 18, 2011 11:10 pm
As much as it was a nice mosaic, the variance in the tiles albedo made by no mean a realistic floor. So I am now trying to find a visual balance.
This is currently revealing more of the noises driving the features along with a cyclic nature from within my code. Two aspects I'll be working at. C&C's welcome !
basic test
Most recent version, same ref texture
Re: Marble tiles
Post by CTZn » Sun May 22, 2011 5:16 pm
Well, that's 99% finished. Copy the code below and paste into a new IGM file to test, material name is tiledMarble. Don't forget to get a nice marble texture and change the path (currently: marble_21_402_by_robostimpy-d34dq4t.jpg) accordingly.
The number of tiles and cement width are easy to configure, however they must be changed into the three material parameters identically, with your lil fingers :)
<?xml	version="1.0" encoding="utf-8" ?>
<scenedata>
	<material>
		<name>tiledMarble</name>
		<phong>
			<texture>
				 <uv_set>default</uv_set>
				 <path>
				 </path>
				 <a>0.0</a>
				 <b>1.0</b>
				 <c>0.0</c>
				 <exponent>2.2</exponent>
			</texture>
			<ior>1.52</ior>
			<exponent>
				<shader>
					<shader>
						<![CDATA[
	#	modify this block in exponent, bump, albedo
		def slicesX() real : 16.0
		def slicesY() real : 16.0
		def gridWidth() real :  0.01
	#	end custom bloc
		def eval(vec3 pos) real :
		if(
			lt(
				min(
					fract(dot(vec2(slicesX(), 0.0), tex())),
					fract(dot(vec2(0.0, slicesY()), tex()))
				gridWidth()
			4.,
			(fbm(tex(), 12) + 1.)*3000.
					</shader>
				</shader>
			</exponent>
			<diffuse_albedo>
				<shader>
					<shader>
						<![CDATA[
#	end custom bloc
#	albedo-specific edit bloc
		def scale() real : 8.
		def octaves() int : 16
#	end custom bloc
		def discretizeVec2(vec2 v2, real slicesX, real slicesY, real offsetX, real offsetY) vec2 :
			vec2(
				floor(doti(v2) * slicesX) / slicesX,
				floor(dotj(v2) * slicesY) / slicesY
			) + vec2(offsetX, offsetY)
		def tiledMarble() vec3 :
				vec2(
					fbm((tex() + vec2(
							fbm(discretizeVec2(tex(), slicesX(), slicesY(),0.0,0.0), octaves()),
							fbm(discretizeVec2(tex(), slicesX(), slicesY(),1.25,1.25), octaves())
						) * scale(), octaves()
					fbm((tex() + vec2(
							fbm(discretizeVec2(tex(), slicesX(), slicesY(),2.5,2.5), octaves()),
							fbm(discretizeVec2(tex(), slicesX(), slicesY(),3.75,3.75), octaves())
		#	GRID
		def eval(vec3 pos) vec3 :
		if(
			lt(
				min(
				gridWidth()
			vec3(0.75, 0.68, 0.5),	# stripes color
			tiledMarble()			# tiles color
					</shader>
				</shader>
			</diffuse_albedo>
			<bump>
				<shader>
					<shader>
						<![CDATA[
	#	end custom bloc
		def pi() real : 3.14159265358979323846264338327950288419716939937
		#	BUMP: CEMENT
		def cementBump() real :
			(max(
				abs(noise(tex()*3000.)),
				 0.5
			) + abs(fbm(tex()*3000.,4))/40.) /800.	# 1m/800 = 1.25mm
		#	BUMP: GRID
		def eval() real :
			if(
				lt(
					min(
						fract(dot(vec2(slicesX(),	0.0),	getTexCoords(0))),
						fract(dot(vec2(0.0, slicesY()),	getTexCoords(0)))
					gridWidth()
				cementBump(),
				0.002
		*	neg(
				max(
					if(
						lt(
							gridWidth()
						1.0,
						0.0
					)*sin(texi()* slicesX() *pi()*(recip(gridWidth()))),
					if(
						lt(
							fract(dot(vec2(0.0,	slicesY()),	getTexCoords(0))),
							gridWidth()
						1.0,
						0.0
					)*sin(texj()* slicesY() *pi()*(recip(gridWidth())))
			) + 1.
					</shader>
				</shader>
			</bump>
		</phong>
	</material>
</scenedata>
Actual version
when it was 90% done... open sky, you'll do better.
Re: Marble tiles
Post by pixie » Sun May 22, 2011 10:59 pm
:shock: Amazing work! Congrats!
Re: Marble tiles
Post by CTZn » Mon May 23, 2011 2:12 am
Thank you pixie, I appreciate it coming from an artist like you :)
If you are fancy editing the custom block, don't miss also the scale() parameter found in the diffuse_albedo, it will drastically change the look of the material:
#	end custom bloc
For instance if you liked the variations found in the first posted picture, you can set it around 1.0 (0.5 or 1. or 2.5, whatever) A scale of 512. or more may still make sense depending on your taste. Don't remove the period though or you'll throw an integer, and that's not what the shader expects.
Talking about wich, the shader is more complex than it should; all this time I tried to bust an element of continuity between tiles to no avail... will update.
Comments and improvements from ISL writers are much welcome !
Doug Armand
Re: Marble tiles
Post by Doug Armand » Mon May 23, 2011 1:19 pm
Absolutely superb work CTZn! :D
am very envious of your ability to program shaders like this :(
Doug
Doug Armand
Re: Marble tiles
Post by CTZn » Mon May 23, 2011 5:04 pm
Well, I always loathed texels :oops: And again, a fair part of the result comes from the input texture.
Glad you like it Doug, thanks a lot !
I'll fiddle with a bit more the next days, I'm pretty sure some spp's can be saved, also I didn't evaluate the exponent bit.
Mor4us
Re: Marble tiles
Post by Mor4us » Sat May 28, 2011 8:10 am
Hi guys,
I'm no Indigo user but always interested in new things ;)
This marble material looks awsome!!!! I've seen a lot of coding up there so i guess this is no simple bitmap material. Can you tell me something more about that indigo procedural materials? Is this an indigo-only thing or would it be possible to generate bitmaps out of it to use in cinema4d or some other 3D software?
Would really love to have this Material!!!
regards
C4D R20 Studio
mad-imagery.com
