Rendering Issue
8 posts • Page 1 of 1
yelfawal
Rendering Issue
Post by yelfawal » Sat Apr 09, 2011 5:04 am
I am new to indigo, and have both indigo &skindigo at versions 2.4.13 on sketchup 8. i keep encountering this problem every time i try to render this particular file. please help!!
SceneLoaderExcep: Failed to load texture '/Volumes/Indigo/Indigo.app/Contents/Resources/TX_default/photon-rug_cream.png': LibPNG error: IDAT: CRC error
Indigo version: Indigo Renderer v2.4.13, OS X 64-bit build.
Exporter: SkIndigo version:2.4.13
Platform: i686-darwin8.10.1
Author: Dale Martens (Whaat)
Description:
Date created: Fri Apr 08 12:51:57 -0400 2011
Please contact support@indigorenderer.com.
compadrelucas
Re: Rendering Issue
Post by compadrelucas » Sat Apr 09, 2011 7:43 am
send the model.
Re: Rendering Issue
Post by Pibuz » Mon Apr 11, 2011 8:34 pm
I hope Whaat will show up soon and solve your issue. I can't help you, sorry.
Re: Rendering Issue
Post by Headroom » Tue Apr 12, 2011 4:25 am
That does not sound like an exporter issue.
I seems that the PNG image is corrupt and can't be read. Try to eliminate it from the scene and see if that helps.
Looks like you're on a mac. Are you able to open the image with Preview ?
Bosseye
Re: Rendering Issue
Post by Bosseye » Sat Apr 16, 2011 1:01 am
yelfawal wrote:I am new to indigo, and have both indigo &skindigo at versions 2.4.13 on sketchup 8. i keep encountering this problem every time i try to render this particular file. please help!!
Description:
If its only that particular file that causes the issue, perhaps its something wrong with that particular png. Try deleting it from your model and replacing with the default material and see if that works.
Re: Rendering Issue
Post by OnoSendai » Sat Apr 16, 2011 1:08 am
Hi all,
Just like to say that all IDAT and CRC png handling errors will now be just warnings (and so the render will work just fine) for the next Indigo release.
Re: Rendering Issue
Post by pixie » Sat Apr 16, 2011 2:15 am
OnoSendai wrote:Hi all,
when? When? WHEN?
:twisted:
Re: Rendering Issue
Post by Pibuz » Sun Apr 17, 2011 8:06 am
Will it be called Indigo as well? There are so many changes you're prophetizing! :lol:
Users browsing this forum: Google [Bot] and 77 guests
