Night Render Issues
9 posts • Page 1 of 1
Frutiger
Night Render Issues
Post by Frutiger » Wed Mar 16, 2011 4:03 pm
Hello again, Indigo renderer community.
I've been working on lighting plans recently, and there's no better time to show off a good lighting plan than at night. I think we're all aware that the main issue here is a complete lack of ambient (ie MOON) light. Here's an example.
LIke the goddamned sun went out.
I'm sure I'm not the first person to run into this problem. So I was hoping I could maybe hear about some people's workarounds and fixes to make it look like actual night time and not the interior of a black hole.
Here's another example.
Again, with the darkness.
I know one way of dealing with it is by jacking up the ISO or EV adjust until it gets filled, but that tends to burn out light sources.
See example:
Toasty
So, are there any generally accepted workarounds for this issue while working in (Sk)Indigo?
Silmä
Re: Night Render Issues
Post by Silmä » Wed Mar 16, 2011 7:08 pm
One good and tested solution to the lack of ambient lightning is to use an ambient light source... Say, a huge, blueish low intensity emitter or night-time hdri-map. It's possible to fake moonlight with the sun/sky model using light layers, but it's doesn't work very well with other light sources due to how Indigo handles layers.
ENSLAVER
Post by ENSLAVER » Wed Mar 16, 2011 7:46 pm
dark bluey purple environment, possibly on it's own layer if you want to play with it later.
There are A LOT of evening/dusk hdri's online, you just have to search around to find the free ones. I've seen some with moon and stars, and also lots of plainer evening ones, some with sunsets.
ex:
http://www.peterguthrie.net/blog/tag/hdr/ (not free)
http://www.hyperfocaldesign.com/sky-tex ... ction.html (not free)
http://crazy8studio.com/hdri.html (free - 7th one down might work well with some colour adjustments)
http://www.openfootage.net/?cat=15 (free - HDRI 360 degree gaisberg at night salzburg looks good)
http://bryceblog.bryce-alive.org/?paged=2 (free - scroll down, lots of night ones - low res)
Or, make your own hdri from Terragen, that way you can get the colours/clouds just right.
http://forums.cgsociety.org/showthread.php?t=298483
http://forums.planetside.co.uk/index.php?topic=36.0
Still if you aren't going to see a lot of the sky/reflections best just to use environment colour. The purble bluey works well with lights because most lighting is a warmer colour, purple is the opposite and can really make stuff jump out.
examples of bluey purple environment:
http://sentimentalfreak.deviantart.com/ ... -164765520
http://sentimentalfreak.deviantart.com/ ... -164773868
Post by StompinTom » Thu Mar 17, 2011 1:32 am
Night are shots usually aren't exactly *night* shots but rather dusk shots. Ambient blue light carries the sense of darkness and night while still allowing you to see what's going on. A perk of this too is that the ambient light nicely contrasts with artificial (usually warm) lights, which is what makes dusk shots so pleasing.
Post by suvakas » Thu Mar 17, 2011 2:05 am
Just a simple dark environment color has done the trick for me in this kind of situations.
Bosseye
Post by Bosseye » Thu Mar 17, 2011 3:26 am
I've done this before by just changing the default sketchup background colour (in styles) to something dark purple/blue and then in render settings change environment to 'sketchup background colour' and leave the black box unchecked. Gives everything a nice dusky, purple hue which as Tom says above contrasts nicely with the artificial lighting.
Post by Zom-B » Thu Mar 17, 2011 3:36 am
how about a simple gradient from dark Blue to black (starting in midle of the black image).
So you have a bluish horizon and a black sky. The image can even stay 1 pixel with ;)
dcm
Post by dcm » Fri Mar 18, 2011 2:48 am
I think that using 150x150px blurred night hdri good option.
Or simple use env. color (no sun/sky) to dark blue and tweak via light layer + set intensity to 0.08 or similiar value - easiest way
Frutiger
Post by Frutiger » Tue Mar 29, 2011 9:53 am
I figured HDRI maps would be suggested. I'll give those a try first. I'll post results up when I get them all polished up.
Thanks for the all the ideas!
Users browsing this forum: No registered users and 172 guests
