WinOsi Caustic Test Scene
Post by CTZn » Wed Feb 07, 2007 10:19 am
If that's what I think this is due to a small value of <large_mutation_prob>, wich cause, as far as I understand, bigger zones to be evaluated with a loss in local color accuracy. That is, big colored zones. When it converges, the zones merge together and form a smooth image.
When you set <large_mutation_prob> higher (but always below 1), it tends to the level of a pixel, not an area of the screen. That is, noise frequency is higher.
That's what I found, what do you think about that ?
manitwo
Post by manitwo » Wed Feb 07, 2007 10:21 am
Kram1032 wrote:You expected this kinda artistic result? Why? Is v0.7 THAT different? Can you "fix" it?
Hi Kram
Thats not really something that had to be fixed - that's because of the way PathTracing works.
In Indigo 0.7 "MLT" and "BiDir" are temporarily disabled. In 0.6 not.
I rendered the 0.6 in the "MLT + BiDir"-mode and the 0.7 in "PathTracing"-mode.
Pathtracing is very good for exteriors and direct lighting but not for indirect light and caustics
(because the emitter is behind a glass-lens EVERTHING is lit by direct and indirect caustics).
But i'm not the one who should explain that - IanT described that much better.
If i find his explanation i'll post a link.
EDIT: http://www2.indigorenderer.com/joomla/f ... .php?t=572
IanC
Post by IanC » Wed Feb 07, 2007 1:04 pm
MLT isn't disabled, just BiDir MLT.
I'm not sure if pathtracing is still in indigo, I haven't used it since back in the 0.4 days.
manitwo
Post by manitwo » Wed Feb 07, 2007 1:16 pm
IanC wrote:MLT isn't disabled, just BiDir MLT.
oops youre right :oops: anyway, this scene is nearly impossible without BiDir.
IanC wrote:I'm not sure if pathtracing is still in indigo,
It is!
IanC wrote:I haven't used it since back in the 0.4 days.
You should. As i said - works wonderfull for exterior and for scene with much direct light. Also some things changed since 0.4 - PT is progressive now :wink:
Post by suvakas » Wed Feb 07, 2007 7:53 pm
Any reason why BiDir is disabled?
Post by fused » Wed Feb 07, 2007 10:36 pm
nick told us not to use BiDir becuase its buggy...
interesting comparison by the way... im really curious why the indigo render looks so different
manitwo
Post by manitwo » Wed Feb 07, 2007 11:11 pm
i dont think it looks too different.
Beside that lines (i posted that in the bug-forum) and the reflective parts
(which aren't show the caustics) the indigo image looks really good.
Especially for that time!
To be sure - you should see two images :D
Redqueen:
Indigo: (3h50min)
Post by Kram1032 » Wed Feb 07, 2007 11:41 pm
redqueen seems to be very fast...
Two questions: what are your settings for rendering in 0.6?
(large_mutation_prob; max_change; max_num_consec_rejections; russian_roulette_live_prob and max_depth)
And: did you change the two smooth spheres to be <sphere>s instead of <mesh>es?
I'm not sure, if you got the answer: The "secret Door" can be seen in the sence with Radium (PT): rendered in 3d by "tg_jp", you posted in the very first post. It's the second image.
And now, as I look at it again, I can see another change:
Behind the door, there should be a cylinder on the wall, but here, it's edgy...
Post by fused » Thu Feb 08, 2007 12:12 am
the redqueen image could use some AA..
and is there a reason why the lightsources look so different? the indigo image has a cross.
i also noticed that the sphrere doesnt really reflect the caustics and the caustics in the indigo image look much more "datailed".
think these two are really different
Post by Zom-B » Thu Feb 08, 2007 12:18 am
Here my result after 36h and 11k muts per pixel:
I'll try now a 0.7t3 version using specular for reflections, not phong...
strange about your rendering manitwo is the "black cross" inside the lenses :?
the main difference about Indigo & the rest of the world is this shadow, the stand throws on the left & right wall...
Post by CTZn » Thu Feb 08, 2007 12:19 am
Another difference seems to be that the mirror material in the Indigo image is not a perfect mirror.
manitwo
Post by manitwo » Thu Feb 08, 2007 1:20 am
Kram1032 wrote:Two questions: what are your settings for rendering in 0.6?
"metropolis" - "true"
"large_mutation_prob" - "0.4"
"max_change" - "0.02"
"max_num_consec_rejections" "100"
"russian_roulette_live_prob" "0.99"
"max_depth" "200"
"bidirectional" "true"
Kram1032 wrote:And: did you change the two smooth spheres to be <sphere>s instead of <mesh>es?
Till now not - but a good idea - i will :wink:
ZomB wrote:Here my result after 36h and 11k muts per pixel:
why are our renderings different? is your lens normal-smoothed?
ZomB wrote:strange about your rendering manitwo is the "black cross" inside the lenses :?
i rendered my pic bigger and resized it after the rendering - perhaps thats why :?
ZomB wrote:the main difference about Indigo & the rest of the world is this shadow, the stand throws on the left & right wall...
right - i believe that shadow is produced because of the bug i posted.
CTZn wrote:Another difference seems to be that the mirror material in the Indigo image is not a perfect mirror.
this might not be a mat-problem, i think they are so dark cause they aren't reflect indirect caustics.
Post by Zom-B » Thu Feb 08, 2007 1:47 am
manitwo wrote: why are our renderings different? is your lens normal-smoothed?
yes, my lens got the XML Tag for smoothing, but I recognized that it hasn't any Phong Tag in the 3DS
(perhaps Indigo even ignores this?!?).
I also recognized that I normal smothed the meshes for the light emitters, perhaps an issue...
I'm rendering now a 0.7t3 Scene now, looks better than the one in your first post :wink:
My Image is so unsharp, because my focus is set to 100 and not about 0.3,
this results in a small DOF for the whole Scene, changed to white_balance E now to to get this redish tint away
Post by Kram1032 » Thu Feb 08, 2007 2:06 am
The funny thing about recognizing you is, that YOU gave me the hint^^
ZomB wrote:
I'm sure small boys would love to play with your balls
:twisted::lol:
@tato: you could use sphere primitives instead of lowpoly sphere meshes.
example (gives you a perfect sphere):
Code:
<sphere>
<center>1 0 0.3</center>
<radius>0.3</radius>
<material_name>mat</material_name>
</sphere>
_________________
cheers,
manitwo
Later, Tato answered:
what i found is that the perfect spheres speeded up the rendering nearly 2 times. from 30k to 55-60k. hm, and gives me different refraction :roll:
So, I thought, it would be faster this way^^
IanT
Post by IanT » Thu Feb 08, 2007 2:29 am
Excellent results manitwo ... although I think you might have to wait a few more days for those reflected caustics to converge (there would be the same problem with Maxwell or any other unbiased renderer too I suspect).
Ian.
Users browsing this forum: No registered users and 91 guests
