help! images come purple
hello for some reason all my images are coming purple (see example) its an exterior view so its not like light is going through any material, and i was making other view form same model and it came perfect, any help would be much apreciated.
- PureSpider
Re: help! images come purple
The first image looks like you set the sun's position below horizon.
When you do that, your renders come out with "purple light" for unknown reasons.
its actually at noon, summer time
Re: help images come purple
Weird, lol, check your geometry, no big objects accidently scaled up to block the normal light? Are the sun and sun target in positions that would make it daytime?
Still, that's too early !
The trivial reason that I know of is the model used. It doesn't allow the sun to be below the horizon (ground). If you need that time of the day, either get a suiting environment map, or model the Earth globe and sun and atmosphere. Heh
Er, noon summer time is about as far away from the horizon as you can get
Perhaps a crazy white-point setting? Checked the light layers? If it persists, pack the scene (Indigo > File > Save as > .pigs) and post it and we'll have a look
Check your global position and time zone. That could throw everything off.elDiego wrote:its actually at noon, summer time
Make sure your camera isn't inside a wall.
Users browsing this forum: Bing [Bot] and 26 guests
