How to Use Motion Blur
Post by Whaat » Sat Jul 18, 2009 5:39 pm
Motion Blur is first implemented in SkIndigo 2.0.8.
How to use Motion Blur in SkIndigo 3.2:
Motion blur still needs lots of work and a better user interface. However, you can play around with it by following these steps:
1) Create a group or component
2) Ensure there are no nested groups or components within. If so, explode them so that the group/component contains only faces.
3) Right-click and 'set keyframe'
4) Enter 0.0 to set the first keyframe
5) Move/rotate the component to a new location
6) Right-click again and 'set keyframe'
7) Enter 1.0 to set the last keyframe (or an intermediate keyframe)
8) Note that you must set a keyframe at 0.0 and a keyframe at 1.0 for the motion blur to work.
9) There is currently no way to 'jump-to' existing keyframes
EDIT: updated instructions for version 3.2
Re: How to Use Motion Blur
Post by Pibuz » Mon Jul 20, 2009 7:33 pm
Thank you Whaat!!!
Here is a nice and smart implementation (congratulations to Ono, Benn and Whaat): that seems to be very easy-to-use, and that's the main characteristic I always seek in Indigo :wink:
Thank you a lot: I'll give it a try for sure!
Cyberdactyl
Post by Cyberdactyl » Fri Aug 07, 2009 7:30 am
Cool. Tried motion blur, very nice effect.
AND it worked for me the first time I tried it!
ideas_arte
Post by ideas_arte » Sun Sep 13, 2009 10:38 am
thank you very much Whaat, very good choice in Indigo and so simple to achieve,
this is my Test!
Nick
Post by Nick » Sun Sep 13, 2009 10:01 pm
Not bad test!!! Thank you Whaat!
djegoo
Post by djegoo » Fri Nov 13, 2009 7:38 am
oh nice! this is quite easy to use! great integration. Thanks for this good work!
PowerMax
Post by PowerMax » Mon Feb 21, 2011 2:10 am
could you please using some pics? :) It's quite complex for me. Please :shock:
buzzkill
Post by buzzkill » Wed Mar 02, 2011 3:32 am
I would like to see some sample images if you guys have tried it yet :wink:
cotty
Post by cotty » Wed Mar 02, 2011 9:05 pm
One example...
(with or without light, I don't know :? )
Cotty
Post by Pibuz » Thu Mar 03, 2011 5:14 am
Not tried yet, but after cotty's test I can't wait for! :!: :!: :!:
buzzkill
Post by buzzkill » Sat Mar 05, 2011 12:36 pm
cotty wrote:One example...
Cotty
Wow those are great! I like the one with lights because it makes you think how in the heck are those lights hitting the metal spheres without breaking!
buzzkill
Post by buzzkill » Sat Mar 05, 2011 12:39 pm
Just so I am reading the directions the right way...
When you move or rotate the object after the "set keyframe" setting, you are moving it to its final position?
cotty
Post by cotty » Fri May 06, 2011 8:30 pm
Little test with motion blur. I discovered an error (?) and would like to know if someone had noticed any comparable.
(a) without motion blur
(b) enable instancing -> move to first position -> set keyframe 0.0 -> move to end position -> set keyframe 1.0 -> ERROR?
(c) move to first position -> enable instancing -> set keyframe 0.0 -> move to end position -> set keyframe 1.0
Cotty
ieatfish
Post by ieatfish » Thu Jun 02, 2011 11:01 am
Found my first use for this today. Whaat, you're awesome. It worked great for a small thing but then I tried a few other things and it stopped. The object that should be moving is rendering away from the correct location even though it hasn't moved in the model.
edit: Attached some images. The first is the Sketchup model. Followed your instructions and only rotated the rotors 15 degrees or so. Then when I render...well, you can see what happens. :p
Intel Core-i7 @ 4.0 GHz | GTX 580 | 12 GB RAM
Post by Whaat » Thu Jun 09, 2011 5:50 am
cotty wrote:Little test with motion blur. I discovered an error (?) and would like to know if someone had noticed any comparable.
Cotty
hmmm...possible bug. Thanks for the report!
