UV problems
- Reinuvader
UV problems
Can somebody explain, what I am doing wrong. Sketchup shows perfectly mapped armchair, but when I hit Render, result is somewhat different. For UV maping I'm using Whaat's UV tools and exporter is Skindigo 2.4.13.
Re: UV problems
I don't use SU, but do you use subdivision of this model in Indigo? It might be the problem for textured models, as far as I know.Reinuvader wrote:Can somebody explain, what I am doing wrong. Sketchup shows perfectly mapped armchair, but when I hit Render, result is somewhat different. For UV maping I'm using Whaat's UV tools and exporter is Skindigo 2.4.13.
- Reinuvader
Re: UV problems
Nope! No subdivision is used. Mesh should be rendered as it is modeled.
Re: UV problems
Hi Rein.. Never used Whaat's UV tools till now..
I think the best choice here is to wait for Whaat to answer..
- Reinuvader
Re: UV problems
UV tools is nice plugin to make it possible to map difficult models with external software. You simply select faces or model you want to UVmap and use UV tools to export those faces to OBJ file. Then map your OBJ using external software (I use UVLayout), when done, save your OBJ and then use again plugin to import OBJ. It doesn't import model but just UV cordinates from OBJ.
I know that there are problems with faces witch have more than 4 edges, but my model consist only of 3 or 4 edged polygons.
If I use Sketchup's projection maping, then everything is OK and Indigo renders the same way you see maps in SU. But sometimes it is impossible to map using ptojection, and thats why one needs UV tools or something else if there is some other plugins.
So lets hope Whaat knows how to solve such problem.
Re: UV problems
..would be interesting to have a small practical tut about how to use the UVtools along with UVlayout too!
There is such a huge lack of tuts about plugins and SkIndigo in general! I'm trying to add my small contribution through my blog, if you're even partly interested... (see link in signature)
- Reinuvader
Re: UV problems
UVLayout tutorials are on their homepage. http://www.uvlayout.com. Without those tutorials it would be almost impossible to use this software because its so shortcut based and there is no way you can figure out those keys on your own (in this respect it's similar to Blender). Its very archaic looking tool but if you get used to it you want to map everything with this software.
Re: UV problems
Thank you for the link. I meant a tut about your SU->UVlayout->SU workflow, btw..
Re: UV problems
Glad to see someone is using my UVtools plugin!
Unfortunately, by using the plugin, you end up with distorted textures. This is a SU issue primarily and I don't think I can fix it.
The only way around it is to have your mesh made up of triangles only. Then it should render properly in Indigo.
I know it's a pain but I think there is a triangulate script available somewhere. You could also convert your mesh to 3DS and then re-export it back into SU. That should make it all triangles.
- Reinuvader
Re: UV problems
Thanks Whaat. This helped.
If you know where problem lies, maybe you could point it out for Sketchup developers. It seems to me that those guys have rested on their laurels for too long. If I'd know the problems core I would do it myself.
- Reinuvader
Re: UV problems
I can't promise you anything, but I definitely think about that suggestion. It would be good idea, because sometimes I need it myself. Mostly because I am frustrated that I have to scroll trough several UVLayout tutorial videos before I get what i'm searching for.Pibuz wrote:Thank you for the link. I meant a tut about your SU->UVlayout->SU workflow, btw..
