some requests
15 posts • Page 1 of 1
dcm
some requests
Post by dcm » Sat Aug 21, 2010 3:12 am
1. integrated ISL to maxigo (like in cindigo, mostly for using perlin noise)
2. cancel button for possibility to cancel exporting process
3. fastbox filter integration
4. default mn_cubic 0.333/0.333
5. more control for material editor (c value, gamma exponent)
6. maxigo (indigo) is ignoring tiling, ofset, angle etc. inside of bitmap settings directly in material
Re: some requests
Post by suvakas » Sun Sep 05, 2010 6:36 am
1.will check this when more urgent things are out of the way
2. done for next gen Maxigo (the "real" render plugin version)
3. done for next release
4. done for next release
5. added to "to do list"
6. done for next release
:D
Anyway..the current roadmap is, that there will be one more (intermediate) version of scripted Maxigo to make it more compatible with upcoming Indigo 2.4. After that the old maxscript code will be abandonned and there will be a new Maxigo release that will act as a render plugin.
Godzilla
Re: some requests
Post by Godzilla » Sun Sep 05, 2010 7:51 am
I'm transitioning to 3ds max, so this is great news :)
Thanks Suv!
Re: some requests
Post by Zom-B » Mon Sep 06, 2010 10:44 am
suvakas wrote:...there will be a new Maxigo release that will act as a render plugin.
Doesthis say, that Maxigo is gona integrate Indigo renderer in Max, hit render and Max will render Indigo output in Max-render-window? by using the SDK?
dcm
Re: some requests
Post by dcm » Tue Jan 25, 2011 11:45 am
Probably
Re: some requests
Post by suvakas » Tue Jan 25, 2011 6:34 pm
The 1st release of Maxigo render plugin will act similar to Maxwell for example.
It means that it still launches Indigo GUI and then grabs the image back to Max.
By render plugin I mean, that the location of Maxigo will go under render panel. This also opens up a lot of possibilities since Maxigo will act sort of like a renderer and not just scripted exporter as it is now.
dcm
Re: some requests
Post by dcm » Wed Jan 26, 2011 1:55 am
GREAT!
ENSLAVER
Re: some requests
Post by ENSLAVER » Wed Jan 26, 2011 2:24 am
Not to hijack a thread but, how's the proxy stuff going? It would be awesome to have a proxy object that you can paint/scatter/etc using already written max scripts and tools (advanced painter, groundwiz, particles, multiscatter, etc)
Using maps is a great way aswell, but if there was a simple proxy object you could let those other scripts/plugins handle the placement, rather than place them all at export (can take a long time if there are lots of objects on a detailed map) - Or a tickbox to "Use precomputed proxy locations"
Also that proxy material with the random colour is looking promising ;p
dcm
Re: some requests
Post by dcm » Fri Jan 28, 2011 12:33 pm
Can you add possibilty to remove loaded EXR map ? It is impossible to remove it and when im archiving scene to zip, its packing it too when im not using it! :)
And what about MaxigoColor ? Internal processing of bitmaps (similiar to colorcorrect) without need of Photoshop ? Just basic functions like contrast,brightness,gamma,saturation,invert etc. Im working with huge bitmaps (8000x8000px) and maxigo have limitation of 2000x2000 as i know.or ? This can really speed up workflow and material creation.
Re: some requests
Post by suvakas » Fri Jan 28, 2011 7:51 pm
From where you can't remove EXR image? From Indigo material or where?
dcm
Re: some requests
Post by dcm » Fri Jan 28, 2011 8:25 pm
environment tab under maxigo. When map is loaded, how to remove it or select "none" ?
Re: some requests
Post by suvakas » Fri Jan 28, 2011 8:46 pm
dcm wrote:environment tab under maxigo. When map is loaded, how to remove it or select "none" ?
What if you un-check the Enable box?
It should disable Exr export.
dcm
Re: some requests
Post by dcm » Fri Jan 28, 2011 9:01 pm
I know this :)
For example now, i have 1.5gb big scene and im moving from max to max (pc / another pc) and when i archive scene from max`s save menu, its zipping 150mb EXR i used - and doesnt matter that its unchecked.
Im using max 2k10.
dcm
Re: some requests
Post by dcm » Thu Mar 10, 2011 12:17 pm
REQ : gamma setting for bitmaps please
edit : i was speaking with ZomB and in cindigo,they have gamma 1 as default for bump / displacement. I do some tests yesterday and gamma 1 is doing difference in bump comparing to 2.2. And i`ve read that inverting gammas are only for albedo maps not for monochromatic bitmaps.
What do you think suv?
Slash_Aeolus
Re: some requests
Post by Slash_Aeolus » Sun May 22, 2011 3:41 am
I would like to ask you man, you is how realistic the material out of tune.thanks
