Skindigo 2.6.1 & Sketchup 8 problem
Hello to everyone. I've installed Skindigo 2.6.1 in Sketchup 8 and when I hit the render button nothing happens. I had the same problem with Skindigo 2.4.13 in Sketchup 8. Materials and camera settings are working fine. Is there a solution? Thanks.
Re: Skindigo 2.6.1 & Sketchup 8 problem
Just checking, have you installed Indigo?
Yes I have installed it. Indigo first and then Skindigo. Same version.
Please check for error messages in the Ruby Console window when you press the render button.
Thanks.
Thanks.
I checked for errors and in the ruby console writes this: [Error: #<Errno::ENOENT: No such file or directory - C:\Users\Anthony\AppData\Roaming/Indigo Renderer>
C:/Program Files/Google/Google SketchUp 8/Plugins/skindigo.rb:1043:in `mkdir'
C:/Program Files/Google/Google SketchUp 8/Plugins/skindigo.rb:1043:in `get_indigo_app_data_path'
C:/Program Files/Google/Google SketchUp 8/Plugins/skindigo.rb:535:in `export'
C:/Program Files/Google/Google SketchUp 8/Plugins/skindigo.rb:1555
C:/Program Files/Google/Google SketchUp 8/Plugins/skindigo.rb:1043:in `call'
C:/Program Files/Google/Google SketchUp 8/Plugins/skindigo.rb:1043]
Then I checked the specified folder above and I opened the "log" icon. It writes: [Tue Jan 18 23:10:07 2011
Executing 'C:\Users\Αντώνης\AppData\Roaming\Indigo Renderer\default-meshes.igs --settings <width>800</width><height>600</height><super_sample_factor>2</super_sample_factor><image_save_period>60.00000</image_save_period><save_igi>true</save_igi><info_overlay>false</info_overlay><watermark>false</watermark><gpu>false</gpu><bidirectional>false</bidirectional><metropolis>false</metropolis><halt_samples_per_pixel>-1</halt_samples_per_pixel><halt_time>-1</halt_time>'
Indigo Renderer v2.6.1, Windows 32-bit build.
Licence not verified, running in free mode.
Scene file path: 'C:\Users\Αντώνης\AppData\Roaming\Indigo Renderer\default-meshes.igs'
Error: SceneLoaderExcep: Could not find root 'scene' element in file 'C:\Users\Αντώνης\AppData\Roaming\Indigo Renderer\default-meshes.igs'.
Stopped].
Stopped].
Any suggestions? Thank you.
It's possible that it has something to do with the characters in your username.
What if you login to Windows with a username with only English characters.
Can you test if this works?
Thanks.
Thanks.
Did this. Works just fine thank you!!!
anesthetized
Hi!
I've got the same problem. Ruby console error says:
Error: #<Errno::ENOENT: No such file or directory - C:\Users\Sawek\AppData\Roaming/Indigo Renderer>
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/skindigo.rb:1037:in `mkdir'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/skindigo.rb:1037:in `get_indigo_app_data_path'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/skindigo.rb:529:in `export'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/skindigo.rb:1535
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/skindigo.rb:1037:in `call'
I have changed my name in the windows user settings, but it doesn't work
Please help!
My installation path is "D:\Soft\Indigo Renderer\" and username "Александр"
I added to skindigo.rb two lines:
ENV['APPDATA']="D:/Soft"
ENV["USERNAME"]="Alexander"
after
module SkIndigo
VERSION="2.6.1"
VERSION_="2_6_1"
RELEASE_DATE="10 January 2011"
It's worked for me
after
module SkIndigo
VERSION="2.6.1"
VERSION_="2_6_1"
It's worked for me
anesthetized
It is all about no-english charakters in username! Silly, but get used to. I just made another user and i change user in windows when i have to render and everything works fine.
take care
take care
You can change your windows username so you won't need to switch accounts.
http://forums.techarena.in/tips-tweaks/1124298.htm
Now who wants to be a good little gineau pig and see if this messes up something?
anesthetized
I have changed my user name first, but it did't work. I'm using windows vista- maybe that's the reason
Hi, I have SKP 8 , Indigo and Skindigo ver 2.6.1 and a huge problem
ObjectExcep: Exception while building tree: Memory allocation failed while building kd-tree
Indigo version: Indigo Renderer v2.6.1, Windows 32-bit build.
Exporter: SkIndigo version:2.6.1
Platform: i386-mswin32
Any ideas? Is there a solution ?
thanks.
thanks.
Probably some mesh is subdivided, you may want to reduce the subdivisions level.
When using subdivisions, one level increase results in 4 times more triangles.
