Canon 5D Mk II - Maya to Indigo
Re: Canon 5D Mk II - Maya to Indigo
Post by CTZn » Sat Nov 06, 2010 4:33 am
I think that ISL lacks access to the parameters Galinette requested in order to simulate lens coating accurately. Oh, but you discussed the problem already !
I remember myself playing with peak spectrums in absorbtion, sss and phase functions and I happened to obtain a material looking like a coated glass, but it was more of an impression than something you want to reproduce and I lost the settings in these serial tests I was doing.
http://www.indigorenderer.com/forum/vie ... =23&t=5576
You can use camera ratio mapping but this effect can be done with ISL for some time already... 2.4.3, if I refer to the special car paint comments from Galinette, in the DB:
http://www.indigorenderer.com/materials/materials/425
However I am not sure that blending supports shaders atm, hence his implementation I believe.
Lemo
Post by Lemo » Mon Nov 08, 2010 8:46 am
Here is what I got so far.
Your material seems nice but quite long to render. I prefer not to go into sss and huge render times with eighteen pieces of glass in that lens, so I went on trying some material based on galinette's pearl. Basically just removing the sss and changing the IORs.
It's almost convincing, but only in a few specific lighting conditions, and the refraction doesn't look right at all...
Would be nice to use that camera ratio mapping, but I'm affraid ISL programming is way beyond my skills, so I guess I'll let it like that for now, to start working on the camera body.
In the meantime, if the devs wanna implement galinette's suggestions, or if someone wanna play with the igm, please be my guest :p.
Somehow_coated_lens.zip
(770 Bytes) Downloaded 824 times
Lemo
Post by Lemo » Wed Dec 08, 2010 1:14 pm
Okay I'll be back on this :)
@CTZn
Stumbled upon a minor issue though.
I reopened the scene, and as I wanted to render the camera with the lens hidden, I had that same problem :?
The test scene "hiddenInstanceBug" I provided now works indeed with mti last release, but my 5D scene got some additional "groups complexity" that may cause problems with those screws.
You can see that the ones inside the hidden "lens" group get rendered, as well as some instanced cubes, that don't even have instances in any other part of the scene.
(They don't get into the render if I hide the actual objects again inside the hidden group)
Here it is:
screwedBug.rar
(45.2 KiB) Downloaded 846 times
Post by CTZn » Wed Dec 08, 2010 3:59 pm
Ah, ok. Thanks for the scene and for your enthusiasm Lemo, I'm on this !
edit: spotted the flaw. Oh that was trivial (one-worder), fixed, upping... done.
By the way, I like the lens render you posted !
Lemo
Post by Lemo » Thu Dec 09, 2010 6:18 am
Thx for the fix, works fine.
Here is a charcoal sketch with glass/mlt :lol:
Post by CTZn » Thu Dec 09, 2010 8:13 am
Hey it's super tricky to get one well defined volume frome such a complex assembly. All pieces must interpenetrate clearly or remain at a distance, coplanarity is to be avoided. It's just a technical hint by the way, art must remain a free expression :)
Have fun !
Lemo
Post by Lemo » Sat Dec 11, 2010 8:00 am
Fun with lasers
Lemo
Post by Lemo » Sun Dec 12, 2010 12:53 pm
Starting to get there
Post by CTZn » Sun Dec 12, 2010 1:48 pm
Indeed !
May I suggest that you test for a non-circular aperture shape ?
Also give a try at smooth-subdividing some meshes (provided that they are not textured, until the next Indigo update). View-dependent parameters can give sort of a texture to otherwise smooth surfaces.
Great mod' so far Lemo !
hcpiter
Post by hcpiter » Wed Dec 15, 2010 2:25 am
wow, good shot, pls show more !
Lemo
Post by Lemo » Wed Dec 15, 2010 12:27 pm
@CTZn
Yeah those parts need some smoothing...
I'm not getting great results with indigo smooth subdivs so far, it kinda look like the camera went into the oven or something ^^'
Also I guess I'm gonna have to apply some kind of slight bump to each part for a more realistic plastic.
But I'll be testing generated aperture shapes indeed !
@hcpiter
wow another comment from a non-mti user thanks :D
Post by CTZn » Wed Dec 15, 2010 4:54 pm
Lemo wrote:@CTZn
Ah... my bad. Yeah, I'm hoping that's part of the things fixed for the next Indigo release. Seems so.
Lemo
Post by Lemo » Thu Dec 16, 2010 10:44 am
Hey CTZn I'm having some issues with bump, and probably normals, this seems to happen with non-square bumpmaps only.
Not saying non-square textures are the best, but that's still an issue I guess.
I don't think it's related to the mesh coz I got the same thing on a sphere.
Btw good point for modified maya shaders here (vs IndigoShader) for bump quick preview in maya renderer.
From left to right Maya Software, Indigo bump texture as bump, Indigo bump texture as color.
Post by CTZn » Thu Dec 16, 2010 6:25 pm
Probably your bump map is too strong, by an order or two.
The final B value in the IGS should be around 0.001m. This means 0.1 in the UI with the default MtI scale (cm). You can use the bump depth as a multiplier for the bump value.
If you believe that the final meter value in the IGS is right then I'll review the recent changes with meshes.
The mesh on your picture is not using subdivisions, right ?
Post by zeitmeister » Thu Dec 16, 2010 10:14 pm
... and remember to use 16bit bump maps...
Users browsing this forum: No registered users and 84 guests
