[REQ] Help me modeling this
13 posts • Page 1 of 1
Post by Pibuz » Tue Nov 30, 2010 2:00 am
Hi guys!
Need a little help here..
I'm trying to model this, but it seems it's too hard for me to get it right, using sketchup..
It's a stretched metal sheet, I'm attaching the technical reference..
Can anybody give me a hand with this? I'm trying to get a tileable model, which I can reply over the portions of facade I have to cover... I don't need it to have a thickness, but it must be a 3D model (not displaced textures..)
Thank you a lot guys..
technical reference
photo shoot
Re: [REQ] Help me modeling this
Post by StompinTom » Tue Nov 30, 2010 4:08 am
Peter Guthrie posted a couple of textures he made to get exactly this material: http://www.peterguthrie.net/blog/2010/0 ... ded-metal/
There's also an explanation of how he generated it, including a screenshot of the model he made.
Basically, since it's an expanded sheet of metal, it's made by cutting little lines into a flat sheet, which is then pulled apart. Below is a little demo I made in Blender very quickly. The thing is you have to then rotate the object so the whole thing lies flat because you end up making a bunch of little 'steps'.
Post by CTZn » Tue Nov 30, 2010 4:46 am
ah, I'm late !
Here's my attempt, not perfect but basic enough to allow you to tweak it. I changed the file extension for upload.
PS: units are centimeters.
for_Pibuz.obj.renamed.zip
The file format is obj, not zip ! remove ".renamed.zip"
(21.14 KiB) Downloaded 278 times
Post by Pibuz » Tue Nov 30, 2010 6:37 am
Hi thom, Hi CTZn: thanks for your efforts!
@Thom: you posted a very useful link, but for this time I really have to use MODELED GEOMETRY (I'd written that in my first post: NOT displaced textures), because I have pretty close views to do.. :?
@CTZn: when imported into sketchup your model (obj) looks somehow messy... Moreover, it is very rough-edged, and I need it to be smooth.. I was thinking about sort of a bended surface, easy to get with 3dsmax, more complicated (as it turned out..) to do with sketchy...
I repeat: 2D geometry will perfectly do the job guys, as a thickness of 1.5mm is not SO visible..
dakiru
Post by dakiru » Tue Nov 30, 2010 12:35 pm
Hey,
here are two .OBJects — one of them is the part for the arrays, without subsurf and arrays modifiers and the second one is the 10x20 net with subsurf and array modifiers applied.
net.rar
(568.14 KiB) Downloaded 325 times
wojtek-w
Post by wojtek-w » Tue Nov 30, 2010 3:02 pm
hi Pibuz,
i've tried to model something like this in the past. I must admit that with sketchup it is little bit tricky. I was in a hurry so i have used some approximation like this attached below back then. It worked for me
siatka_w_ramie.rar
(38.81 KiB) Downloaded 240 times
Post by CTZn » Tue Nov 30, 2010 3:55 pm
Oh ok, it's coming messy... well its supposed to be smoothed to an extent after assemby. Fair enough, didn't model a thing for a while :)
Post by StompinTom » Tue Nov 30, 2010 4:32 pm
Pibuz wrote:Hi thom, Hi CTZn: thanks for your efforts!
I know, which is why I also posted an image of a very basic way of modeling it. The reason why I posted Peter's blog post was that he also shows screenshots of how he made modeled geometry of the thing, which are pretty easy to reverse-engineer.
Post by Pibuz » Wed Dec 01, 2010 5:33 am
Sorry Thom. I didn't mean to be edgy.. very sorry. I really appreciated your link, it's only that it's not very helpful THIS time. It will be for sure very soon though..
galinette
Post by galinette » Wed Dec 01, 2010 5:41 am
Displaced mesh using a ISL shader could be very realistic, even in close-ups! Don't forget that ISL has infinite resolution.
Etienne
Eclat-Digital Research
http://www.eclat-digital.com
Post by Pibuz » Wed Dec 01, 2010 5:48 am
It's a pity that I don't know ISL shader coding even a tiny bit..
I actually thought about this solution: suddenly thrown in the trashcan given the fact that I don't know ISL coding at all, indeed..
dakiru
Post by dakiru » Wed Dec 01, 2010 11:51 pm
Hi, Pibuz, did you try the model I've posted? From you definition it might work for you. :wink:
Post by Pibuz » Thu Dec 02, 2010 1:13 am
Hi dakiru. I had some timing problems yesterday, but I gave your model a look last night: seems to work almost good. I have the feeling that the holes are a little too stretched, but it is something I can fix (I think) ... OR ... I'll leave them like they are now and pretend they're actually like that :wink: :lol:
Users browsing this forum: No registered users and 70 guests
