How to make Indigo to use 80% of CPU ?
If I render with Indigo 0.6 or 0.7, my PC turns of becuase of overheating I guess. So I was thinking if I can make it use less CPU, maybe CPU wouldn't overheat. Is it possible?
Under windows search for something like this:
http://www.donationcoder.com/Software/M ... index.html
greetz,
jur
PS. maybe time to vacuum CPU?
greetz,
jur
Hey motorsep,
Earlier this day I've been searching for such apps in Sourceforge.net, and everything I found was for Linux, a few for OSX however, and none for Windows. Now I've searched again on the www and found this one, wich I haven't tested tho:
ThreadMaster
It is supposed to CLAMP cpu usage, so that's what you need I guess. Lowering process priority won't avoid the maximum usage of the cpu, while this one is supposed to have success here.
Cheers
ThreadMaster
Cheers
How do you know that the issue is heat? With the subject of overheating we have the luxury of being objective. This website answers some basic questions and provides a chart of cpu max temperatures:
http://www.heatsink-guide.com/content.p ... temp.shtml
Here are some links to apps that monitor your cpu temp:
http://www.almico.com/speedfan.php
http://www.lavalys.com/
Keep in mind, though, that on-board sensors aren't very accurate. Whatever the software says probably shouldn't come within 6 or 7 degrees celcius of the posted max. Zsouthboy's suggestions are a good place to start if heat really is the issue. Is your system over-clocked?
My CPU is not overclocked. And I don't think I have any sensors, because I have old Dell system Dimension 4300S (P4 1.4 GHz)
I can't tell for sure if it's overheating. But since system shuts down on render, I assume it is.
It happens only if I render with Indigo. And shut down happens maximum 1 hr after render has been started.
