Tips are welcome and needed!!!
Bullets
Bullets
Hi!, Im new at this and just wanted to show some bullets I tryed making... I think the base of the bullet needs to be thinner and the texture needs some adjustments.... tnks!
Re: Bullets
Hello and welcome, Albert_fn!
That's a nice scene and you are right that the bullets are too shiny on the first render, but you've nicely fixed this on the second.
The only two crits that I would have:
1. The primer of the bullet is of the different material, mostly nickel-plated.
2. There are visible waves near the edge of the primer. I guess adjusting the crease of the edge loop (part of it marked red) might help here. Otherwise, that's a very nice render
edit: and yeah, there are mostly vendor and caliber stamped around the primer
- kikeonline
Re: Bullets
Good Start
Re: Bullets
Did you use CU.NK for the tip of the material by any chance? I have tried doing this with bullets, and it always results in a metal that is too bright. But the composition is definitely fantastic. Nice work.
- 300px-9mmLuger.jpg (14.88 KiB) Viewed 23129 times
Re: Bullets
Hey everybody! thanks for your replies!
I actually used http://www.the3dreality.com/NK_materials.html
Cr3si.nk for the base and a mapped exponent material and for the tip I used Cu.nk and the same.. exponent
I started the bullet just to try some stuff, I even forgot to look for some real scales and messurmens (MY BAD)
I noticed the waves on the primer next day... I just left the computer on rendering for kicks
and actually liked what the result was... Im defenetly gonna take your advice and finish it
- Borgleader
Re: Bullets
The link doesn't seem to be working for me
Edit: fixed your link, realty --> reality
Re: Bullets
Thanks!!, I tried copy paste, but I don't know wy it doesnt work for me on the forum.Borgleader wrote:The link doesn't seem to be working for me
- kikeonline
Re: Bullets
I recomend you to use a Blended Material so you have more control over refelctions
- Borgleader
Re: Bullets
http://www.indigorenderer.com/materials/materials/97
Not quite the same but close enough, you could always adjust it to your liking
Re: Bullets
Tiara just the one I wanted to use at first... But did not see any result, I dont kbps why
Users browsing this forum: No registered users and 160 guests
