Indigo 2.6.1 Released
Phoenix
Re: Indigo 2.6.1 Released
Post by Phoenix » Thu Oct 07, 2010 10:11 am
OnoSendai wrote: 30-Day Trial
First off, there is now a 30 day trial that will start as soon as you install this beta. The trial allows you to render at unlimited resolution for 30 days. There will however be relatively subtle watermarks over the high resolution image. After the 30 day trial has expired, you can still render at <= 0.7 Megapixels with the single Indigo watermark in the lower right corner.
Is this beta version a 30 days trial only or does it also work as an unlimited full version for licensed users?
FakeShamus
Post by FakeShamus » Thu Oct 07, 2010 10:45 am
any chance for a mac build of this to try out?
the glass acceleration would really help out on a couple things I'm working on.
Post by fused » Thu Oct 21, 2010 3:53 pm
Hey,
added a mac build.
Soup
Post by Soup » Thu Oct 21, 2010 4:54 pm
Phoenix wrote: Is this beta version a 30 days trial only or does it also work as an unlimited full version for licensed users?
If you have a full licence installed, then Indigo will remain fully operational. The 30 day trail is only for unlicensed users.
Frank Schroer
Post by Frank Schroer » Thu Oct 21, 2010 6:38 pm
Hello
i cant find the Option "Architecture Glass" in my Renderer!
I edit my INI-File too, but--- nothing!
Can u help me?
Frank
Post by lycium » Thu Oct 21, 2010 7:01 pm
Hi Frank,
That's strange indeed; please confirm that you added <glass_acceleration>true</glass_acceleration> into your renderer_settings, using Indigo 2.6.1, and are rendering thin, double-sided glass (i.e. the usual Indigo glass volume with a medium inside). I've downloaded 2.6.1, installed it, edited the INI file and it works here, so it's probably some minor configuration problem.
Post by fused » Thu Oct 21, 2010 7:11 pm
lycium wrote:Hi Frank,
also, it currently only works with bidirectional.
I will release a 2.6 version of Cindigo, which will have an option for it, in the near future, along with a R12 version of the 2.4 stable exporter.
Phoenix
Post by Phoenix » Fri Oct 22, 2010 2:19 pm
Thank you, for finally answering my question! :o)
In this case, I can dare to test this version too. ;o)
fused wrote:I will release a 2.6 version of Cindigo, which will have an option for it, in the near future, along with a R12 version of the 2.4 stable exporter.
That are really good news! :o)
Tartiflette
Post by Tartiflette » Thu Oct 28, 2010 12:40 am
fused wrote:Hey,
added a mac build.
Hi there.
Is there a way to test that Mac build ?
I can't find any link to it.
Cheers,
Laurent aka Tartiflette :)
Post by fused » Thu Oct 28, 2010 10:00 am
Tartiflette wrote:
fused wrote:Hey,
added a mac build.
Hi there.
Cheers,
Hey,
sorry, I removed that build because it had quite a serious issue that resulted in (pretty much) random crashes. We will release Indigo 2.6.2 soon with a new mac build.
Tartiflette
Post by Tartiflette » Thu Oct 28, 2010 10:25 am
fused wrote:Hey,
Ah ok, that explains why i didn't find it ! ;)
Looking forward to that version, while i try 2.4.13 and find it enjoyable already ! :D
Cheers,
Ecifircas
Post by Ecifircas » Mon Nov 22, 2010 7:26 pm
Can this beta be used with the sketchup exporter?
Post by lycium » Mon Nov 22, 2010 9:26 pm
Yes, it should be compatible with the latest versions of SkIndigo exporter.
aprincipe
Post by aprincipe » Thu Dec 02, 2010 3:25 am
When I try to download the trial it says I can't because its a virus.
Virus Download Blocked
Download of the virus has been blocked in accordance with company policy. Please contact your system administrator if you believe this is in error.
Post by CTZn » Thu Dec 02, 2010 6:40 am
What is your anti-virus software (you said "it") ? It is probably inefficient, if not harmfull. Does it allow you to download other executable files (*.exe) over the web ?
Here's the analysys log from the award-winning av I'm using:
Start of the scan: mercredi 1 décembre 2010 19:42
Starting the file scan:
Begin scan in 'D:\dwnlds\3d\indigo\IndigoRenderer_x64_2.6.1_Setup.exe'
End of the scan: mercredi 1 décembre 2010 19:42
Used time: 00:00 Minute(s)
The scan has been done completely.
0 Scanned directories
480 Files were scanned
0 Viruses and/or unwanted programs were found
0 Files were classified as suspicious
0 files were deleted
0 Viruses and unwanted programs were repaired
0 Files were moved to quarantine
0 Files were renamed
0 Files cannot be scanned
480 Files not concerned
1 Archives were scanned
0 Warnings
0 Notes
You probably want to uninstall or unactivate your pretending protecting software in order to download Indigo, however I can not take responsability for the actions you have or will take on your computer.
The Indigo archive is safe.
