Ark (spaceship)
Ark (spaceship)
After trying numerous freely available textures (and not being happy with any of them), I went ahead and made my own.
Suggestions on everything welcome..
Re: Ark (spaceship)
Looks too big to be in Earth's atmosphere, I think you need to render it in space!
Re: Ark (spaceship)
You could use the texture as a faint displacement instead, that would figure panels better. Subdivisions smoothing should be off then. As a bump map it would be better slightly blurred, it's a bit too contrasty for an albedo map. To my taste that is
Re: Ark (spaceship)
Update. Added more detail to both the top and bottom of the ship.
Re: Ark (spaceship)
There's a weird grid going on in those two last ones! Does it clear if you render longer?
Re: Ark (spaceship)
Not really. The image cleared after 15 minutes or so and I let it render for another 45 mins and it didn't change much. The ship was only scaled to around 800 feet.
Indigo 2.4.13//AMD P320 Dual core cpu//Bidirectional PT
Re: Ark (spaceship)
We've recently improved the numeric precision of Indigo's camera calculations, which could resolve this issue.
Re: Ark (spaceship)
I'm not following this, in what way does this help?lycium wrote:We've recently improved the numeric precision of Indigo's camera calculations, which could resolve this issue.
Re: Ark (spaceship)
Regarding the strange box pattern over neo0s last renders...CoolColJ wrote:I'm not following this, in what way does this help?
Re: Ark (spaceship)
Slight update. I wanted to give it a more armored, industrial look.
Re: Ark (spaceship)
Please give this envMap a try for a better space look: http://www.hdrlabs.com/sibl/archive/dow ... lkyway.zip
More reflections for the surface could enhance the look to.
Re: Ark (spaceship)
Nice sunny day out in space, not a cloud in the sky!
Re: Ark (spaceship)
Yes, I love you! I have been looking for a space HDR for many months. Thank you, Zom-B!Zom-B wrote:Please give this envMap a try for a better space look: http://www.hdrlabs.com/sibl/archive/dow ... lkyway.zip
As for the reflections, I am going for for a dull, painted metal look..
Re: Ark (spaceship)
Use a very low exponent for a dark phong then ! Removing totally the specular component of an object is like removing the color from a picture (to me) ! Only that even b&w pictures are featuring specularity so it's even worse realism wiseneo0. wrote:As for the reflections, I am going for for a dull, painted metal look..
You are making good progresses neo0. !
Re: Ark (spaceship)
The environment map seems to be a little bleary and out of focus, but on the whole it looks much nicer. Does anyone else here know of any other space HDRs?
