Voronoi ISL Shader
Voronoi ISL Shader
Not as difficult as I first thought!
Do you see some applications of it for real world materials? Maybe stone walls or the like.
Next step is to have a thin border between cells
Etienne
Etienne
- voronoi.igm
- (1.43 KiB) Downloaded 604 times
Eclat-Digital Research
http://www.eclat-digital.com
Re: Voronoi ISL Shader
Here are some other example applications of this shader
That's very cool.
I'm trying to work out how your code works
One tip: you can use the < operator instead of lt().
great work galinette!!!
This is something that should be integrated directly in Indigo, just like FMB & perlin Noise!
Hmm, what would the shader return? Index of cell?Zom-B wrote:great work galinette!!!
Noise shaders are barley used pure as they are in material creation. Having a simple call via ISL would simplify usage for regular users.OnoSendai wrote:Hmm, what would the shader return? Index of cell?
From the control of cell size over to a 0 to 1 scale for "smoothness" off the cell inner to a border scale etc.
From the user point of view I see this integrated into the Exporters just like Yves did with gradient & noise in Cindigo
Perhaps a (edited:) distance between points ? A distribution from ordered to random would be cool (optionally seeded).
For a realistic, parametric reptile skin, both the distances between points and their randomness in distribution should be non-wavelength dependent parameters, that is float or grayscale data driven. Me thinks
I mean, with an actual reptile mesh. Painting the scales size and randomness would be a great option ! Argh, can't help pushing nevermind me
Absolutely!! This is a very good primitive for many shadersZom-B wrote:This is something that should be integrated directly in Indigo, just like FMB & perlin Noise!
I could write you some specs!OnoSendai wrote:Hmm, what would the shader return? Index of cell?
I see at last two interesting : the center of cell (vec2), the distance to center of cell (real)
The two last images use the latter, I'll upload soon.
Etienne
That's exactly what the shader used in the two last images do (modified since the first one). I'll upload soon as soon as I have more time to work on this...CTZn wrote:Perhaps a (edited:) distance between points ? For a realistic, parametric reptile skin, both the distances between points and their randomness in distribution should be non-wavelength dependent parameters, that is float or grayscale data driven. Me thinks
Sure, that would be great!galinette wrote: I could write you some specs!
Also If I had more of an idea how the Voronoi cells would be used in shaders, that would help.
[/quote]Also If I had more of an idea how the Voronoi cells would be used in shaders, that would help.[/quote]
I will post some material using them soon...
Example picture:
http://www.google.fr/imgres?imgurl=http ... 4Qb1vrnIBg
Etienne
Example picture:
Etienne
I love the dry mud idea!
Etienne
Etienne
Mostly, it is usefull for rural/natural structures, walls an stone paths. A simple application could be as a blend between a stone and a mortar material:
http://www.tandtmasonry.com/Stone%20Pedestal.JPG
http://www.google.com/imgres?imgurl=htt ... =104&ty=43
Could cells indices play a role in affecting blended shaders like for the above (per cell hsv) ?
Yes, of course. Thats quite straightforward.
The only thing that is somewhat complicated is to make:
- The border between cells
- The irregularness ( non straight borders )
Etienne
Etienne
