I´m pretty satisfied with it, but I´m sure the experienced guys here will have some hints do do it even better.
On 10 cores about 4-5 hours, the "light tent" picture in the middle about 1h.Soup wrote:Yeah it's pretty good! The glass is really clear and nice, did you render for long?
Only thing that maybe could be improved is the texture of the baseboard.
Did you denoised your images? The floor texture seem to suffer under denoising
Atm the latest GPU beta versions only support 1 Graphic Card. This may be changed in future! The GPU beta is quite early in development, so lets see what we'll get under the Christmas treeZlaty Lev wrote:Longing for the gpu acceleration because I have 2 graphic-cards with cuda.
Since I uploaded it to the DB I just recognized the little difference that results from denoising in the texture appearanceZlaty Lev wrote:Yes denoised, but the difference on the fooring is not very big. As you can see on the sample.
The part between the red area is denoisd, the rest regular.
I think it´s the texture. Its from the material library here on indigo.
Yes, they are really great! Some textures can now even be bought separate from the site. Only thing to think about is the gigantic resolution the textures are in! Indigo loads the Textures and convert them to "raw data", so a tiff or jpg end up in taking same amount of memory.Zlaty Lev wrote:I thought about buying arroways textures. That would also be better for the baseboard. Anybody with knowledge about them here?
I can highly recommend the Arroway textures. The DVD versions also come with resized JPGs from the original hi-rez PNGs. Much more practical to use for rendering as it's still got pleeenty detail, but you always have the hi-rez full version to fall back on.Zom-B wrote:Yes, they are really great! Some textures can now even be bought separate from the site. Only thing to think about is the gigantic resolution the textures are in! Indigo loads the Textures and convert them to "raw data", so a tiff or jpg end up in taking same amount of memory.Zlaty Lev wrote:I thought about buying arroways textures. That would also be better for the baseboard. Anybody with knowledge about them here?
For some projects it might be a good idea to reduce the resolution of these textures to save RAM, but actually... RAM is so cheap ^^
Neat ImageLemo wrote:That denoising seems to work quite well.
Can you tell us wich software you used?
Users browsing this forum: No registered users and 88 guests
