No Render settings menu
I am using Mac OS X version 10.6.3 and just installed the software and going through the tutorial but cannot find the render settings menu. I clicked on the camera and it selects but no menu shows up. I when through the plug-ins menu and found it there but when it selects again no menu shows up. The materials editor menu seems to work fine though as well as the "Render with Indigo".
Am I just overlooking something?
Re: No Render settings menu
Hi! Welcome to Indigo!caribarch wrote:I am using Mac OS X version 10.6.3 and just installed the software and going through the tutorial but cannot find the render settings menu. I clicked on the camera and it selects but no menu shows up. I when through the plug-ins menu and found it there but when it selects again no menu shows up. The materials editor menu seems to work fine though as well as the "Render with Indigo".
This sounds quite strange. Can you please open the Ruby Console Window prior to clicking on the 'camera' icon and report any error messages that are displayed.
Also, have you tried another SKP file? Do you have the same problem regardless of the SKP file you are using?
I am also having this problem. When I click the camera icon it changes to a darker gray suggesting it is open but no window pops up. I have tried it with a few sketchup files and it's not working with any of them.
Try clicking the 'camera' icon with the ruby console window open. Are there any error messages in the console when you click the button?L_S wrote:Hi,
There's a long message in the Ruby Console. I have no idea what it means but it says:
Error: #<Errno::EACCES: Permission denied - /Applications/Indigo/Indigo.app/Contents/Resources/SUthumbnails>
/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/SkIndigo/IndigoRenderSettings.rb:399:in `mkdir'
/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/SkIndigo/IndigoRenderSettings.rb:399:in `thumbnail_path'
/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/skindigo.rb:2547:in `loadValuesFromSU'
/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/skindigo.rb:2444:in `refresh_dialog'
/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/skindigo.rb:2453:in `show'
/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/skindigo.rb:768:in `render_settings'
/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/skindigo.rb:514
/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/skindigo.rb:1515:in `call'
/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/skindigo.rb:2422:in `initialize'
/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/SkIndigo/IndigoRenderSettings.rb:399:in `call'
- fractal.design
Any progress on this? This is really annoying...
I get this error also:
Does this mean the permissions need to be opened on that file for the current user?
(If so I will let the admin know)
Note: This issue might be related to the indigo version?
Cheers.
Error: #<Errno::EACCES: Permission denied - /Applications/Indigo/Indigo.app/Contents/Resources/SUthumbnails>(If so I will let the admin know)
Cheers.
People who are having this problem, can you please post your Indigo version?
Thanks,
nick
Thanks,
nick
Indigo Renderer v2.4.11, OS X 64-bit build.
Another question for you guys is:
is this a new problem? Have you had previous versions of Indigo/SkIndigo that were working properly?
We have had a previous version - the render settings function worked fine on that one.
And I havent been able to seen the render settings menu with this version at all
I was also having this problem.
A MacPro are running OSX 10.6.4 with Indigo 2.4.13 and Sketchup 8.0.3161.
Everything was freshly installed today.
I looked in the console log and saw a bunch o what looked like permissions problems....
12/12/10 9:36:57 PM [0x0-0x19c19c].com.google.sketchupfree8[6570] #<Errno::EACCES: Permission denied - /Applications/Indigo/Indigo.app/Contents/Resources/renders>
I opened up the permissions on everything within the /Applications/Indigo directory and now my render settings come up.
(I know this isn't an ideal solution but it worked for me)
I hope this helps..
johnk
I hope this helps..
johnk
My understanding was that this issue was resolved in the final stable version of Indigo 2.4.
