Official: IES lighting effects with Indigo
Tutorials/guides/tips on how to use Indigo and the Indigo exporters
Soup
Post by Soup » Wed Nov 18, 2009 12:46 pm
Hey there everyone, I've just started here at Indigo to work on the documentation and will submit all new tutorials through this forum to get feedback on them.
The first of this series is for the technical manual and focuses on IES lighting.
Download the attached PDF, and you can get a zip of some nice IES files here
A IES viewer can be downloaded from here
Please let me know if you are having any problems with it, or spot some bad wording and I'll get right on it!
Cheers!
-$oup
*edit* Updated, used plane instead of box
Techniques_IES.pdf
IES section of the Techniques Manual
(131.14 KiB) Downloaded 3340 times
WytRaven
Re: Official: IES lighting effects with Indigo
Post by WytRaven » Fri Nov 20, 2009 11:13 pm
Nice clean and clear writing style. Nice :)
Post by Headroom » Sat Nov 21, 2009 2:03 am
Concise and to the point. Nice! I like the links to the IES files and the viewer.
Could use a little hint that the IES light source shines in the direction of the surface normal of the emitting surface.
Also, as IES file contains the light intensities but no color information, so a hint to set the color would be helpful. The blackbody temperature for a given light source can usually be obtained on the manufacturers website.
It should be mentioned that Indigo only works with IES files that do not contain a vertical angle that is larger than 90deg if my memory serves me right. Indigo responds with an error message if that's the case.
Jeff Hammond
Post by Jeff Hammond » Sat Nov 21, 2009 4:31 pm
interesting and informative. thank you
looking forward to more
[edit] oh, about the actual pdf.. it'd be nice if the links were hot.
djegoo
Post by djegoo » Mon Nov 23, 2009 1:16 am
hi
i just downloaded this tut and now, what is an IES + how to use it is totally clear for me.did not think it was that easy ! THanks a lot.
good job.
jebusk
Post by jebusk » Sat Dec 05, 2009 3:25 am
Thanks a lot for this.
Post by neo0. » Thu Dec 31, 2009 6:04 pm
Nice. This is exactly what I have been looking for. It might be a good idea to link these IES emitters from the main download page too.
mutnem
Post by mutnem » Sun Jan 31, 2010 12:56 pm
that was great thanks
cholme
Post by cholme » Sat Mar 27, 2010 7:23 am
Hello. I downloaded the files but I keep getting the following error. I am using Sketchup.
"SceneLoaderExcep: IESDataExcep: IESDatumExcep: Error parsing num_lamps"
I have no idea what this means... any help would be greatly appreciated.
Thanks
Post by CTZn » Tue Mar 30, 2010 2:40 am
Hi cholme, your IES file is trying to define more than one luminaire, this is not supported by Indigo at the moment.
cholme
Post by cholme » Tue Jun 08, 2010 9:21 am
I am sorry, I don't totally understand. I only created 1 emitter, and pointed the IES file to one of those that I downloaded. I don't know why it is trying to use more than one luminary... Please explain.
Thanks.
Post by CTZn » Wed Jun 09, 2010 12:14 am
Different IES specifications exist, and Indigo doesn't read them all. In your case cholme, the IES file is defining more than one luminary and that's the problem.
If you are lucky you can find the different luminaries defined in separated IES files, if you are techie you can try to operate yourself, or ... pick another one !
cholme
Post by cholme » Sat Jun 12, 2010 4:53 am
I am not quite techie enough to know what I am looking for in the IES files. Has anyone had luck using these files with SketchUp? I tried IES files 1-6 from the files in this thread and all of them give me an error.
need2blend
Post by need2blend » Thu Sep 09, 2010 1:44 am
I am having the same problem each time I try to render, it gives me the same error "SceneLoaderExcep: IESDataExcep: IESDatumExcep: Parse error, failed to find 'TILT'"
Please help.
Bosseye
Post by Bosseye » Thu Jan 20, 2011 9:23 pm
Just thought I'd chuck another post in this thread - I've been trying out the IES files on the link above and I'm getting the same errors as the other guys for 90% of them.
Any chance of someone shedding some light (ah ha ha) on this? I'm in the dark (ah ha ha) as to why these don't work.
