Indigo Renderer 2.4.8 Released
Re: Indigo Renderer 2.4.8 Released
Post by StompinTom » Wed Aug 11, 2010 4:05 am
Emitting materials + sunlight seem to crash Indigo. Indigo crashes on rendering (Indigo.exe has stopped working).
perth_algonquin_int1.pigs
(101.78 KiB) Downloaded 703 times
galinette
Post by galinette » Wed Aug 11, 2010 6:08 am
What is salmon noise in indigo? Searching this in the posts gives no answer! ( and neither in google...)
Etienne
Godzilla
Post by Godzilla » Wed Aug 11, 2010 6:31 am
galinette wrote:What is salmon noise in indigo? Searching this in the posts gives no answer! ( and neither in google...)
Etienne
Salmon-colored noise (light pink)
Post by OnoSendai » Wed Aug 11, 2010 1:04 pm
StompinTom wrote:Emitting materials + sunlight seem to crash Indigo. Indigo crashes on rendering (Indigo.exe has stopped working).
Fixed for 2.4.9.
The crash is due to Oren-nayer being an emitter and having zero albedo. Use diffuse instead for your emitters for now.
Post by zeitmeister » Wed Aug 11, 2010 9:48 pm
Great job guys, it seems to be lightning fast with my house scene!
I like the GUI improvements a lot!
But there are still minor issues:
- the bottom info line ist still being cropped when the window is scaled smaller than the rendered image (as seen in the attachments)
- light layers panel input fields, buttons and text are still half size of the rest of the GUI (e.g. the default)
- some issues in the GUI variants, see the attachments
But as I said, great job anyway... rock on, guys!
Ryouta Sumeragi
Post by Ryouta Sumeragi » Wed Aug 11, 2010 11:41 pm
I installed V2.4.8 in NotePC.
However, the error occurred and it was not possible to start...
I'm sorry it is written in Japanese.
The message of the purport that "Side By Side composition" is not correct.
The event log was the following content (It was made machine translation because of Japanese).
- It failed in the generation of the context of making actively of "C:\Program Files\Indigo Renderer\material_editor.exe".
- The error of the manifest or the policy file "C:\Program Files\Indigo Renderer\Microsoft.VC90.OpenMP.MANIFEST" line 4.
- It doesn't agree to ID of the component that component ID in the manifest is demanded.
- The reference is Microsoft.VC90.OpenMP,processorArchitecture="x86",publicKeyToken="1fc8b3b9a1e18e3b",type="win32",version="9.0.21022.8"
- The definition is Microsoft.VC90.OpenMP,processorArchitecture="x86",publicKeyToken="1fc8b3b9a1e18e3b",type="win32",version="9.0.30729.4148"
- Please execute sxstrace.exe to do a detailed diagnosis.
Is there something a good method?
WindowsVista(32bit SP1), Mem4(3)GB
Post by fused » Wed Aug 11, 2010 11:53 pm
Uploaded a new mac build that works with osx 10.5 and 10.6. See first post :)
@Zeitmeister:
We are aware of these issues and they will be fixed by the time of the final 2.4 stable. That the info line is still cut off in some cases is new to me. :S
Thank you for reporting!
edit: also fixed the linux links
Post by Zom-B » Thu Aug 12, 2010 3:18 am
Regarding GUI based stuff, if you anyway work on it here a few things to polish:
1) After rendering reaches halt condition, the image don't get updated (saving via GUI also saves "old" image!)
Pressing "update image" doesn't help here! Also tonemapping layers etc. don't work... quite useless!!!
2) The histogram don't get updated if you change stuff in the light Layers!
3) After loading a scene in Indigo it would be nice, if all the settings could be updated to the scene parameters, atm only resolution gets set!
4) Zooming down for the image results in bad quality downsize filter (NearestNeighbor?!). Could be a better algo be used for this, so the image Aliasing stops raping our eyes?!
Post by neo0. » Thu Aug 12, 2010 9:43 am
Has the issue with alpha rendering been resolved?
Post by lycium » Thu Aug 12, 2010 11:56 am
Ryouta Sumeragi: Thanks for the report, we'll put out a fixed build soon.
Zom-B: Thanks also for reporting these important issues! I'll have a look at the image downsizing soon, right now it's using straight Qt zooming which we couldn't get to work with bilinear filtering. I'll write some code to do this fast :) Regarding light layers and histogram:
Neo0: we haven't looked it yet sorry.
Ryouta Sumeragi
Post by Ryouta Sumeragi » Fri Sep 03, 2010 7:18 am
Is Salmon noise such the one?
I'm sorry when wrong.
Post by Borgleader » Fri Sep 03, 2010 7:20 am
Ryouta Sumeragi wrote:Is Salmon noise such the one?
afaik that seems to be chromatic aberration i could be wrong though
Ryouta Sumeragi
Post by Ryouta Sumeragi » Fri Sep 03, 2010 6:58 pm
Thanks.
The following values were used.
Glass=IOR1.6:Cauchy=0.01
Water=IOR1.33:Cauchy0.005
I found here and try other values.
http://en.wikipedia.org/wiki/Cauchy%27s_equation
