Interior Test, need assistance
sculptera
Post by sculptera » Thu Sep 02, 2010 4:15 am
Hey guys,
First post! I come from a Mental Ray background and am now testing an Indigo release that a friend has been gracious enough to cook for me. Im very impressed with the overall 'feel' of the images coming out of Indigo, but im a bit perplexed by the noise issue.
Here is a test Im working on from an old Evermotion scene. This cooked for 15 hours on an Intel i7 920 2.7Ghz machine.
Settings: Splat, box (attempt to trade off sharpness with noise), Mitchell netra, Ring .6, Blur .3
MLT+bidir.
Im particularly interested in the noise around the coffee table glass (not arch glass, but glass with precedence 6, no dispersion) and under the sofa on the floor. Also, in the built-in wall shelves.
I understand the wall shelves would theoretically need a ton of ray lookups to smooth this out, but im curious if this thing should be cooking longer?
File is downsized from 2k res. I also took some 'creative' liberty in Post in Pshop. :mrgreen:
Any tips would be helpful!
Re: Interior Test, need assistance
Post by Zom-B » Thu Sep 02, 2010 12:54 pm
Hey sculptera, welcome to Indigo :)
Regarding your questions, just a few notes:
Try Box Fastbox filter for faster convergance link1, link2
Your Scene also "begs" for usage of Exit Portals to speed up rendering a lot, did you used some?
Your MN Filter for SuberSampling Downsize Calculation @ R=.6, B=.3 is maybe not best choice. High R Values tend to preserves noise, what about the good old 0.333/0.333?!
Precedence In Indigo is only interesting if various Specular Materials overlap with each other (Glass+Wine for Example) higher Precedence "wins" and cuts off lower: You end up with perfect wine filled glass without any air between glass material & Wine material.
Regarding The Noise in the shelves & under the Sofa I would encourage you trying the Fastbox filter + A ExitPortal for the window.
Also try for the Curtain material to blend it with a Diffuse Transmitter Material (50/50) so some diffuse light passes throough and they don't look that solid ;-)
hcpiter
Post by hcpiter » Fri Sep 03, 2010 9:27 am
maybe change color mapping ? now in scene is too big contrast. Clock from Vitra I think is too big, turn on right lamp and maybe add some spot lights (IES)
Profoxcg
Post by Profoxcg » Mon Sep 20, 2010 6:29 pm
hey guys,
I am a MR user also trying out Indigo. but I am not getting very good results. I understand the concept of the exit portals. Where do you place them? For instance in the windo there is glass. Do you place them right behind the glass on the outside, or do you convert the glass surface into an Exit portal?
Post by Zom-B » Mon Sep 20, 2010 6:34 pm
Profoxcg wrote:...you place them right behind the glass on the outside...
Thats the way to go :)
Also keep polycount low as possible for fastest rendering and maybe this material can suit your needs.
its fake and to reflectiv mostly since fresnel law isn't working here, but its faster then basic glass, also only use it for thin, non volume, planes...
if ever possible, let window glass away to speed up rendering (windows that are out of camera sight for example!)
Profoxcg
Post by Profoxcg » Mon Sep 20, 2010 6:50 pm
Thanks for the reply. You know, I have been deleting glass on these small test scenes I am workign with. Mainly because I was selecting all the object and applying an PLAIN ingido (gray) matrial to do some clay renders.
I have seen some incredible work in the galleries I hope to learn the program so that I buy it and be productive with my investment.
I have a question, how do you typically light a scene like the one above, spot light behing the window somewhere, and a "plane" right outside the window working as the Exit portal? And delete the glass since its not seen bc of the exposure.
(I love the kitchen on your site was that done in indigo?)
Post by Zom-B » Mon Sep 20, 2010 7:12 pm
Some Exporters offer a easy "clay render mode", where they export each material as a light grey diffuse or Oren nayar material, but keeping bumpmaps and displacement, also light materials aren't changed (Cindigo for C4D for example).
Lighting a scene with Exit portals also has the disadvantage, that no mesh (lights) are possible behind this portals.
This indeed results in following possibilities:
1) use sunlight
2) HDRI EnvMaps
3) expand the Exit Portal into a kind of box arround your opening
some things to mention:
1) Sunlight only is sometimes boring and not enugh for your needs :/ (Glare told some time ago that using sun + envMp is on the ToDo list)
2) EnvMaps are gread. The lack of hard light & resulting shadows in some otherwise great maps can be "fixed" by enhancing the EnvMap lifghtSources (sun mostly) in Photoshop or gimp to be brighter!
3) is some situation this is a great trick, like for example having a balcony with objects on it. But beware: To much openings covered by Exit portals maybe sometimes faster without them at all, a quick test will tell :)
keeping glass away from lightsources is always a good way to speed up rendering. for example a lightbulb, modeled and light the natural way is great for a closeup, but if not seen in the picture, simply use a simple sphere to emit light instead...
Thanks for the kind works about my work :) The Kitchen scene in the private work section on my site is rendered in Indigo, as everything that looks somehow realistic ;-)
Profoxcg
Post by Profoxcg » Mon Sep 20, 2010 7:50 pm
so you are saying its either a light object or a exit portal but not both?
Post by Zom-B » Mon Sep 20, 2010 7:56 pm
yes, no meshlights behind a Exit Portal possible atm in Indigo!
In a room lit by sun and Exitportals on the window openings, using meshlight inside like a bulb for example is no problem :)
Post by Pibuz » Tue Sep 21, 2010 9:49 pm
An exit portal cuts off whatsoever object behind itself, excepted sunlight (that is NOT an object).
Use portals if you want to get sunlight, emitters if you want only a diffuse lighting.
Post by zeitmeister » Tue Sep 21, 2010 10:54 pm
… you mean an exit portal cuts off whatsoever object behind itself. :mrgreen:
Post by Pibuz » Wed Sep 22, 2010 1:11 am
damn.... thank you Zeit...It's been a lapsus.. :!: :oops:
Post by zeitmeister » Wed Sep 22, 2010 3:35 am
:mrgreen:
Profoxcg
Post by Profoxcg » Wed Sep 22, 2010 5:20 am
very good guys. I was not aware of the definiont of a MESHLIGHT. So now it makes sense. When I said Light object I meant a LIGHT in 3dsmax for instance not a meshlight.
Post by Zom-B » Wed Sep 22, 2010 5:41 am
Indigo only suports meshlights, envMaps (HDRI lightning) and sun/sky
All lights you use in Max should be converted to meshlights... afaik
In Indigo you can't emit light out of nowhere (pointlights) or have invisible lightsources... atm
Users browsing this forum: No registered users and 142 guests
