Exit Portal Material doubt
Come here for help & support.
8 posts • Page 1 of 1
gmaisg
Post by gmaisg » Wed Aug 25, 2010 7:28 am
Hi, I have a doubt. Lets say I have a render from inside a house (interior scene) and have some big glass windows, do I have to create a plane with a EXIT PORTAL material covering the hole of the window? What I want is to have the glass material (the effect) in the window but with the light coming from outside. Thanks in advance.
:D
Re: Exit Portal Material doubt
Post by Borgleader » Wed Aug 25, 2010 7:33 am
What you can do is create a plane behind your glass with the exit portal material and make sure it's normal is facing the camera. It should in theory let light in, but not out.
Also make sure your glass object has volume :)
gmaisg
Post by gmaisg » Wed Aug 25, 2010 8:04 am
Hi, thanks for the rapid reply. I will try it and was what I was thinking in doing.
besta regards
:D
Post by Pibuz » Tue Aug 31, 2010 7:49 pm
If not extremely necessary, I'd suggest you not to have thick glass, to avoid longer render times.
For me Thin Glass does the job most of the times. 8)
gmaisg
Post by gmaisg » Tue Aug 31, 2010 10:59 pm
Ok, thanks for the advice. I will do that.
Best regards
:D
Godzilla
Post by Godzilla » Wed Sep 01, 2010 2:43 am
Post by Pibuz » Wed Sep 01, 2010 2:58 am
..isn't it thin glass?
gmaisg
Post by gmaisg » Wed Sep 01, 2010 3:05 am
Well, that's great. Various setups, depending the speed that I will want in my renders, thanks for all of you, very usefull.
best regards :D
