Network Rendering
3 posts • Page 1 of 1
Spotter
Network Rendering
Post by Spotter » Mon Aug 30, 2010 5:16 am
I'm interested in network rendering for Indigo.
How is the workload distributed? Does each node have a full copy of a scene in memory? Do the nodes communicate with each other to complete a task, or does the main client PC simply divide the task up and each node does it's own portion?
Say, for example I have a high res scene with lots of polys. Normally, I would need a PC with 8GB of memory to render this. Would it be possible to have 3 networked nodes with 4GB of memory each to complete the task?
Re: Network Rendering
Post by fused » Mon Aug 30, 2010 11:48 am
Hey Spotter,
each node has a full copy of the scene in its memory. The rays bounce around in the whole scene, so they have to. The nodes do not communicate with each other, they only communicate with the master.
No, unfortunately not. If the scene needs 8 gigs of ram, each render node will need 8 gigs of ram.
Post by Zom-B » Mon Aug 30, 2010 10:26 pm
regarding RAM usage there are some things that can be done to reduce it:
Scene Size
- Use instancing as much as possible!
- if Indigo Subdiv is used, try to set it to view dependend & Pixel treshold to 2
- Ultra High res EnvMaps eat up a lot of RAM, reduce size if not visible as BG
- Texture Resolution can be sometimes reduced. Image compression isn't interesting, Indigo always take the pixel data RAW and uses same amount of RAM for a TIFF or highly compressed JPG.
- try to use ISL shaders for noise, gradients etc. instead of HighRes textures
Render Buffer
- Super sampling raises the Buffer by render internally in higher resolution, try to reduce it!
- Light Layers: Each light Layer doubles the Render Buffer
- If rendering with Sun, take care to render Sun & Env Color in 1 Layer
Other
- use your renderslave with indigo_console to save a few MB ;-)
Basically the render Buffer is the biggest RAM killer!
Users browsing this forum: No registered users and 118 guests
