Great to hear, that it worked for you.
As a side note, what scale are you using for your scene? When the scene is un-naturally large, then it may happen, that a 100w light is not generating enough light to lit the place. If you want to use other tone mapping methods than Reinhard, then play with the scale parameter on Maxigo exporter panel. Try smaller scale values first.
