missing materials
7 posts • Page 1 of 1
cathleen
missing materials
Post by cathleen » Mon Oct 29, 2007 12:25 am
Hello i am new in Indigo and i tried to put metal and plastics material on my objects, but my material editor doesn´t look like the one in the max tutorial. I havent got metal, or plastic material.
can anybody help me please?
yours sincerly cathleen
Post by suvakas » Mon Oct 29, 2007 12:38 am
Hi cathleen,
What Max tutorial are you refering to?
If I remember correctly, then plastic and metal materials were present in one older exporter made by a guy called U3dreal. Maxigo is a bit different so those older tutorials do not work anymore.
cathleen
Post by cathleen » Mon Oct 29, 2007 12:50 am
Hi suvakas,
i have tried the tutorial named:
Tutorial Video 2: creating a basic scene, adding indigo materials, and a quick setup for rendering
which is aviable in here for download.
Can you tell me how i should make metal material for example please.
nice greetings cathleen
Post by suvakas » Mon Oct 29, 2007 1:09 am
For metal you should use Indigo Phong material type.
"IOR" value increases the reflectivity and lower "Glossiness" value gives you more glossy reflections.
You can also use some "scientific" presets. If you enable "Use NK data" option, then you can browse for NK data file in you Indigo's root dir under "nkdata" folder. Those contain pre measured data, that have spesific characteristics of a material they represent. Files are named after chemical elements.
I hope it helps!
[edit]
Here is a good reference for NK files:
http://deeppixel.uw.hu/projects/NK_materials.html
tomacmuni
confusing
Post by tomacmuni » Mon Dec 10, 2007 8:57 pm
isn't it a bit confusing that IOR increases reflectivity in a phong, and lower glossiness values give more glossy reflections?
Post by Kram1032 » Tue Dec 11, 2007 2:43 am
uhm, no...
It's not a glossiness-value but an exponent. It has the advantage of allowing infinite steps in glossiness :)
And IoR also changes reflectivity in reality :)
psor
Re: confusing
Post by psor » Tue Dec 11, 2007 5:29 am
tomacmuni wrote:isn't it a bit confusing that IOR increases reflectivity in a phong, and lower glossiness values give more glossy reflections?
Nope, it's quite correct ... but in the "oldschool" days you might learned
something different. And always a good read --> Neil Blevins CG Education
... so go on and have fun! ;o))
take care
psor
"The sleeper must awaken"
