image 1=All advance setup defoult. test=Super Sample Factor (ssf)=1(defoult 2)
Display took 1.19267 s
Time elapsed: 11 m, 47 s
Done 12980000.00000 samples (51.92000 samples per pixel)
18341.24290 samples / second (54.52193 micro-seconds / sample)
image 2=All advance setup defoult ssf=1, BIH=500 (defoult 500000)
Display took 0.97504 s
Time elapsed: 11 m, 41 s
Done 10660000.00000 samples (42.64000 samples per pixel)
15192.51621 samples / second (65.82188 micro-seconds / sample)
saving tone-mapped image to 'renders/2.png'
done.
image 3 All advance setup defoult. ssf=1; BIH=500; Max Num Consec Rejections=500 (defoult 1000)
Display took 0.82964 s
Time elapsed: 11 m, 55 s
Done 12200000.00000 samples (48.80000 samples per pixel)
17042.53235 samples / second (58.67673 micro-seconds / sample)
saving tone-mapped image to 'renders/3.png'
is'it possible to set by defoult this parameter?the result it's good I think!
I attend your comment
filippo sorry for my poor language
little speed test
little speed test
- image 1
- 1.JPG (193.43 KiB) Viewed 2041 times
- image 2
- 2.JPG (198.02 KiB) Viewed 2041 times
- image 3
- 3.JPG (191.87 KiB) Viewed 2041 times
BIH actually slows down your render
shouldn't be that low.
MNCR hasn't any effect on the render speed. It prevents fireflies on cost of caustics.
Higher values will show more caustics and faster but will cause many fireflies, lower values wont show neither caustics nor fireflies at all (extremely low)
CCJ wrote, for the new releases, the default value of 1000 is quite ok.
