Maxigo 0.9.4
Maxigo 0.9.4
Post by suvakas » Mon Sep 17, 2007 6:36 am
Ok. Here it is - a brand new Maxigo version.
It has been quite a while since the previous release =)
There has been A LOT of changes. I re-wrote about 50% of the code (mostly related to geometry export).
Compatibility should be increased (at least i hope so). I tryed to implement the whole "fix mesh errors idea" into exporting process so everything is made automatically now. One interesting detail i added is the automatic export format selection. The original idea came from Kosmokrator (i think...). Everything larger than 65k polys will be exported into *.obj format. Smaller models into *.3ds format and very small models and models without Indigo material into XML format. That should also give some increase in exporting speed. The manual selection is also possible (like it was before).
OK. What else.. I added the Presets feature. Parameters that are saved into a preset are: Advanced setup , Environment, Tone mapping, most camera parameters and some from main Export rollout as well. There are some example presets included. You can also define your own default preset by checking "Save As Default". Then every time you reset Max scene or open up the Maxigo for the first time you have your own default parameters loaded.
Another small feature i added is automatic camera creation. It is now possible to export directly from perspective viewport.
I also did a small notification dialog. It asks you if you want to turn on the sky (if the sky is off) when you create a light type that is accepted as a sun for Indigo (you have to start Maxigo to enable it)
Global scale works correctly now.
Instances should work better + they can have different materials. (while they do work without the Indigo material applied i still advise you to always use Indigo materials for instances...and well..for everything actually)
+ some other small bits and pieces.
Here is the change log:
Changes in v.0.9.4:
* added - Gamma parameter for background color (Environment rollout)
* added - Global gamma (Tone Mapping rollout)
* added - "Number of samples to reach" (Export Scene rollout)
* added - Automatic export format selection (Export Scene rollout)
* added - Separate export elements for geometry, scene and camera (Export Scene rollout)
* added - Units selection list for global scene scale (Export Scene rollout)
* added - Timer for export process (shows last exporting time in seconds) (Export Scene rollout)
* added - "Start Indigo" checkbox (when unchecked, then Indigo won't start) (Export Scene rollout)
* added - If "Number of threads" is set to zero, then Indigo auto-detects the number of cpu threads
* added - "Use instancing" (Advanced Setup rollout)
* added - Auto-notification to turn on sky when compatible light is created (Advanced Setup rollout)
* added - Saving and Loading presets (Presets rollout)
* added - Possibility to turn normal smoothing ON or OFF for selected models (Utilities rollout)
* added - Violet setup (when defined, then Violet is used for opening igi's) (Indigo setup rollout)
* added - Automatic scene scale detection from 3ds max system units
* added - Automatic camera creation when no camera present (3ds max viewport rendering is possible now)
* added - Support for actively linked geometry
* fixed - Global scene scale works correctly now
* fixed - better instancing support
* changed - Geometry export completely rewritten. It should increase the overall compatibility
* changed - Materials Import/Export updated (no import for diffuse_transmitter mats though)
* changed - Wider F-Stop range (Camera Parameters rollout)
* changed - ExitPortal modifier renamed to "Maxigo-ExitPortal"
* removed - "Fix Mesh Errors"(from Export Scene rollout)
* removed - "Auto-split models" (from Advanced Setup rollout)
[edit]
* added - Diffuse Transmitter to phong material
(forgot to add that to the list :wink: )
I'm sure there are a lot of new bugs too. So please give me some feedback how it works. It's almost completely new Maxigo. It sure is the largest update after the first release so...
Have fun!
Suvakas
Maxigo 0.9.4.zip
Latest Maxigo version for Indigo 09 (september 2007)
(329.45 KiB) Downloaded 605 times
Kosmokrator
Post by Kosmokrator » Mon Sep 17, 2007 6:41 am
:shock: :shock: wow...finaly a new exporter........lets test it!!!!
thnx for the update suvakas!!!!!
:yes its my idea and all greets go to you who implement this !!!! :wink:
8) :arrow:
psor
Post by psor » Mon Sep 17, 2007 7:17 am
Awesome update, thanx a lot! :D :D ;)
take care
psor
"The sleeper must awaken"
JaMon_3D
Post by JaMon_3D » Mon Sep 17, 2007 11:22 pm
Thanks a LOT Maestro Suvakas!!!
Cheers,
JaMon
vansan
Exellent!!!
Post by vansan » Tue Sep 18, 2007 7:57 am
Thank you Suvakas, you've done a great job! Keep it up :wink:
10 mln. polys, instances test.
15 minutes render on Q6600!!!
Post by Kram1032 » Tue Sep 18, 2007 8:09 am
OMG O.o
I want to see the guy, who plays all those at once O.o.o.O
Post by suvakas » Tue Sep 18, 2007 8:15 am
Cool ! 8)
I hope you didn't do the mats manually :wink:
vansan
Post by vansan » Tue Sep 18, 2007 8:42 am
:lol:
I used that script for it :)
Here is my 1680x1050 wallpaper render:
http://www.uploadgeek.com/uploads456/1/wallpaper.jpg
random_phong_materials.rar
(1.12 KiB) Downloaded 341 times
CoolColJ
Post by CoolColJ » Tue Sep 18, 2007 1:53 pm
how long did that atke to render :o
vansan
Post by vansan » Tue Sep 18, 2007 7:17 pm
First picture - 15 mins.
Second - 1 hour.
CoolColJ
Post by CoolColJ » Tue Sep 18, 2007 7:18 pm
damn quad core rocks!
filippo
Post by filippo » Wed Sep 19, 2007 2:45 am
wonderful......news.....thaks
ils_fl
Post by ils_fl » Wed Oct 03, 2007 3:23 am
I can't get it to render - what version of indigo is compatible with this exporter? I use 0.8 with 0.8.3b plug and it works but not with this one.
Post by suvakas » Wed Oct 03, 2007 3:56 am
The supported Indigo is inside Maxigo version number. Maxigo 0.9.4 -> 0.9 means, that it's for Indigo 0.9 and 4 means, that it's the 4th release of Maxigo.
There is also a file description in the first post of this thread and it says: "Latest Maxigo version for Indigo 09 (september 2007)". So guys, please try to follow the info that is out there already. Ok?
ils_fl
Post by ils_fl » Wed Oct 03, 2007 4:40 am
sorry I'm new to this - so does that mean that version 0.9 test 7 is actually the latest stable version, not the 0.8?
