ITS TIME FOR NEW....
Here you are, Suvakas.
There is no saving of material properties here, only working interface.
Hope this helps you in development.
[/code]
plugin material Indigo_Material
name:"Indigo Material"
classID:#(1787142791, -1209055881)
extends:Standard replaceUI:true version:1
parameters main rollout:params
rollout importIGM_mat_properties "Import .IGM Material Properties" -- rolledUp:true
label importIGM_mi "ImportIGM Material Interface" fieldwidth:45 offset:[-90,0]
rollout diffuse_mat_properties "Diffuse Material Properties" -- rolledUp:true
label diffuse_mi "Diffuse Material Interface" fieldwidth:45 offset:[-90,0]
rollout phong_mat_properties "Phong Material Properties" -- rolledUp:true
label Phong_mi "Phong Material Interface" fieldwidth:45 offset:[-90,0]
rollout blend_mat_properties "Blend Material Properties" -- rolledUp:true
label Blend_mi "Blend Material Interface" fieldwidth:45 offset:[-90,0]
rollout params "Material Class"
checkbutton importIGM_b "ImportIGM" checked:false tooltip:"Opens ImportIGM Material Properties Rollout Floater" align:#left width:60 height:25 offset:[-5,0]
checkbutton diffuse_b "Diffuse" checked:false tooltip:"Opens Diffuse Material Properties Rollout Floater" align:#left width:48 height:25 offset:[60,-30]
checkbutton phong_b "Phong" checked:false tooltip:"Opens Phong Material Properties Rollout Floater" align:#left width:48 height:25 offset:[112,-30]
checkbutton blend_b "Blend" checked:false tooltip:"Opens Blend Material Properties Rollout Floater" align:#left width:48 height:25 offset:[164,-30]
on importIGM_b changed IGM_State do
if IGM_State == true then
RemoveRollout importIGM_mat_properties
RemoveRollout diffuse_mat_properties
RemoveRollout phong_mat_properties
RemoveRollout blend_mat_properties
AddRollout importIGM_mat_properties
diffuse_b.checked = false
phong_b.checked = false
blend_b.checked = false
else (RemoveRollout importIGM_mat_properties)
on diffuse_b changed diffuse_State do
if diffuse_State == true then
AddRollout diffuse_mat_properties
importIGM_b.checked = false
else (RemoveRollout diffuse_mat_properties)
on phong_b changed phong_State do
if phong_State == true then
AddRollout phong_mat_properties
else (RemoveRollout phong_mat_properties)
on blend_b changed blend_State do
if blend_State == true then
AddRollout blend_mat_properties
else (RemoveRollout blend_mat_properties)
on create do
-- setup initial material
Hey, thanks !!!!!
I'll check it out right after work today.
[edit]
Eh.. i went through the code and it seems, that the only ones i missed when i tryed to do it were: RemoveRollout and AddRollout commands
I guess i missed those in help file
Thank you ! This will sure be helpful. I'm not going to convert everything into one material in next release, but I will start working on it.
[edit2]
There is one more thing i can't figure out. How can you start without any (or some) rollouts and add them later according to what button gets pressed? (similar to selecting different shader types under standard material). I can't find the correct event to remove all the rollouts that are not initially needed.
[edit]
[edit2]
here you are!
-----------------this action closes all unneeded rollouts-----------------
on params open do
-----------------end of this action------------------
Thank you !!!
I'm 99.9% sure, that i tried "on rollout open" event. Maybe i had a syntax error or something
Thanks again!
I wonder how much of the code i have to re-write in order to convert most of the stuff to one material. We'll see. I'm sure it will be better and more organized than having a lot of small different materials.
@vansan
How well do you know maxscript? You seem to be quite good at it...
The whole Maxigo thing is a very very very first thing i've ever done with maxscript...
That's also one of the reasons the script is still encrypted. It just looks like a big mess.
Thanks again!
@vansan
Just like you, I'm newbee to maxscript. Had to read alot of scripts from scriptspot.com and BlurScripts Pack to get how things really work.
So, I just do most of my scripts with manual, copy-pasting and macrorecorder set On
The most complex of my scripts is a material converter. It's here:
http://scriptspot.com/3ds-max/maxwell-m ... -converter
Is that so?
You really sounded like a pro.
I mostly use the help file and it can be quite confusing sometimes.
I've also got some help from master Bobo and from some other guys in internet forums.
Nice converter. Maybe you can do one for Maxigo? (you know..if you need to kill some time or something...
By the way, I've got an idea - what about adding two buttons to the material interface:
"Save Material State"
"Load Material State"
They can be in the lower right corner of the rollout, where you choose the material type.
Saving material states is very handy when you make several previews and need 2 go back to preffered material settings.
No, just 3dsmax's material properties saved to disk. (IGM, supporting that feature will be even better, though
As there will be only all-in-one material - it's good to have an option to quickly switch between different colors and textures.
The reason 2 do so is that I can loose my previous material, assigning new one instead of previous, if I forgot 2 make a copy of it
And one more thing - I'm really angry, working on a scene having many variations of the same material in a scene, sometimes I apply different ones to different objects and in the end I have 10 asphault materials, 15 grass materials, 5 glasses and so on.
Hard to change something on a complex scene.
So, it's a really handy feature that nobody ask for, not really a must-have, but I will be happy 2 get
