It's bug?(Update 02.11,2007)
Post by suvakas » Sun Oct 14, 2007 12:24 am
I think i fixed the bug.
Scene scale for first image is mm and for second image it's cm.
Xman
Post by Xman » Sun Oct 14, 2007 1:31 am
Thank suvakas, and I'm sorry forget amend 3dsmax of units.
update waiting for you are Maxigo :D
Xman
Post by Xman » Sun Oct 14, 2007 1:41 am
I met a new problem today.
At some scene, Indigo working 10 or 20 minutes hereafter, Indigo auto stop.
Who have similar problem?
Post by suvakas » Sun Oct 14, 2007 2:50 am
Make sure you don't have any specific time amount or NumberOfSamples entered into Maxigo
Check the log file after the rendering stops.
Xman
Post by Xman » Sun Oct 14, 2007 3:08 am
suvakas,
maybe you test the scene.You can know more clear. :wink:
From my test,The problem at 7 ~ 12 minutes. AMD3800+X2 2G RMB
From my friend,The problem at 10 ~ 14 minutes. E6300 2G RMB
Xman
Post by Xman » Sun Oct 14, 2007 3:10 am
scene
TES.rar
(2.32 MiB) Downloaded 324 times
Post by suvakas » Sun Oct 14, 2007 7:11 am
Xman wrote:suvakas,
Cool scene Xman. I like it!
On my quad core it finishes after 5 minutes :wink:
This is not a bug. It is a feature. Check out the screenshot. Indigo automatically finishes rendering after it reaches the amount of samples that is entered into that field. In your case it is 100. This feature is very useful for animations for example. If you want Indigo to keep rendering forever, then leave that field to zero.
Xman
Post by Xman » Sun Oct 14, 2007 6:09 pm
Thanks suvakas,I get it Now :wink:
Xman
Post by Xman » Fri Nov 02, 2007 7:41 am
suvakas,it is a new problem. :?
Looks if use Milllimeter, it can't work accuracy.
3ds Max9.0,indigo v1.0.1,Maxigo0.9.4a
Milllimeter and Ctest copy.jpg (329.66 KiB) Viewed 4659 times
Xman
Post by Xman » Fri Nov 02, 2007 7:44 am
scene
max for scene.rar
(821.35 KiB) Downloaded 288 times
Post by Kram1032 » Fri Nov 02, 2007 9:42 am
millimetres means, your scene is 10x as big as before...
SO, you need to increase your ray nudge distance by ten times ;)
Post by suvakas » Sat Nov 03, 2007 1:26 am
Xman wrote:suvakas,it is a new problem. :?
"Display units" can be whatever you want to see writen behind your units on Max interface (it could as well be your granny's name :wink: ). The real units Max uses for the scene are under "System Units Setup". In your case it's inches. So when you use millimeters your model gets very small and that's why there are artifacts. You should use inches for this model or you can scale your scene to use millimeters. To do that change your System Units to millimeters and reopen your scene. From the dialog that pops up pick "Rescale the file to the system unit Scale".
Ps. Maybe i should add a check box to Maxigo that auto-picks the units from Max System Units panel.
