I don't do some image with the camera in the correct position...
as I must setting the camera to have all scene to focus?
I try with autofocus, but the image it's out of focus!!!
setting to camera?
I had already signalled the problem: how I make a material to ceramic of the bathtub?
thanks
problem with canera and material
- max view
- vista max.jpg (63.67 KiB) Viewed 1967 times
- render view
- camera1.JPG (22.89 KiB) Viewed 1967 times
First: if you dont want this to like like a 1cm big bed you'll have to lower the aperture-radius. (or higher the scene-scale)
Second: autofocus messures the distance from the cam to the object in the middle of the image (which is the pillow). Set the focus point/distance manually (dont know how this is handled in maxigo tho
Third: for ceramic i would try a light-grey phong with an ior of ~1.5
hope this helps
hope this helps
