mirror again
mirror again
Hej There,
As I searched throughout the forums this question asked several time.
How to make a mirror material in max.
Without touching the xml files.
Is that possible? (latest maxigo version)
If possible please write me an example parameters.
Somehow I was unable to make it.
Thanks for the help.
According to http://deeppixel.uw.hu/projects/NK_materials.html Diamond works like you described...
I'm not sure, but nk Files seem to describe _only_ the reflection of a material, not the refractive part, so the diamond NK file might be correct but not give you the expected results.
Hey jinj,
You could start with these settings and tweak from there.
It's based on ZomB's material:
http://www.indigorenderer.com/joomla/fo ... ht=diamond
i don't know how physically accurate it is though.
- diamond_mat.png (32.3 KiB) Viewed 383570 times
thank's for replyng Suvakas.
I try this setting. I know that ior value for diamond 2,419 is.
in maxwell if you flag ''use full ior'' the ior file can be used to simulate the real material whitout any other setting.
I open whit wordPad the IOR file and the nk data file containing diamond data. so The two files contain exactly the same information, listed in the same mode. So i Think that the exporters translate the two information in two different mode.
Thank's again.
jinj
Thank's again.
jinj
smrutibora
Re: mirror again
I attempt this setting. I realize that ior esteem for precious stone 2,419 is.
in Maxwell in the event that you banner ''utilize full ior,'' the ior record can be utilized to reproduce the genuine material without some other setting.
I open whit WordPad the IOR document and the ink information record containing jewel information. so The two records contain the very same data, recorded in a similar mode. So I Imagine that the exporters interpret the two data in two diverse modes.
Users browsing this forum: No registered users and 105 guests
