I will do some test to compare the G.I quality between the indigo 0.6 and indigo 0.7.
Beacuse equal setting of tonemapping between indigo 0.6 and 0.7 it is able' to give different result?
camera =auto
material diffuse 242
light=sun
tonemapping pre 2,2----post 2,2---burn 0,8
filippo
Io sto testando la qualità di G.I. tra indigo 0.6 e 0.7..perchè a parametri uguali ci sono differenti risultati?
filippo
"equal parameters different results"(ing-ita)
there are the method to calculate the differences?suvakas wrote:I think tonemapping has changed a bit in 07. At least the burn value. Now it can be > 1, but in 06 it was < 1.
Suvakas
filippo
c'è un metodo per calcolare la differenza?
filippo
