IndigoMax 0.6.3
13 posts • Page 1 of 1
IndigoMax 0.6.3
Post by OnoSendai » Tue Jun 20, 2017 1:20 am
IndigoMax-0.6.3-installer.exe: http://downloads.indigorenderer.com/dis ... taller.exe
IndigoMax-0.6.3-RT-installer.exe: http://downloads.indigorenderer.com/dis ... taller.exe
Supported max versions: 2013, 2014, 2015, 2016, 2017.
Changes:
0.6.3
Fixed crash when rendering material previews in some cases, particularly with slate material editor.
Fixed exposure preview crashing.
Fixed forrest pack transformation issue.
Faster tonemapping.
Fixed activeshade scene updating not working (broken recently).
0.6.2
Fixed Indigo Subdivision modifier having no effect.
Fixed view-dependent subdiv checkbox having no effect.
Set default value for view-dependent subdiv to false.
Added num smoothings subdiv option.
tar_gniK
3D Software: 3ds Max
Re: IndigoMax 0.6.3
Post by tar_gniK » Tue Jun 20, 2017 7:42 am
Thanks Ono. :D
Jay-ko
Re: IndigoMax 0.6.3
Post by Jay-ko » Tue Jun 20, 2017 7:46 pm
Hello there,
Could you do something about the Blend + Null material.
Null material is not present in the selection, you have to use an external .igm, but the result give always an invalid one.
It was working in the past.
errare humanum est
Re: IndigoMax 0.6.3
Post by OnoSendai » Wed Jun 21, 2017 3:03 am
Jay-ko wrote:Hello there,
Ok, I think we'll add Null as a material type in IndigoMax.
Re: IndigoMax 0.6.3
Post by suvakas » Thu Jun 22, 2017 9:16 pm
Nice to see some life in Max land !
I can't figure out how to use activeshade. It doesn't let me to select Indigo as an activeshade renderer.
Also the selection of GPU's is not stored. I have all my GPU's marked, but I keep geting an error message that i need to select a GPU for rendering.
Using max 2016 here.
Suv
Jay-ko
Re: IndigoMax 0.6.3
Post by Jay-ko » Sat Jun 24, 2017 3:28 am
Multi-materials and emitting properties are not linked.
For example here, the result in the model2 is nothing than default "None" emitting properties in the material (be careful to the uids)
so total black image in Indigo.
errare humanum est
tar_gniK
Re: IndigoMax 0.6.3
Post by tar_gniK » Sun Jun 25, 2017 1:09 am
OnoSendai wrote:Ok, I think we'll add Null as a material type in IndigoMax.
We also need 3dsMax Standard maps supported as well, like previous iterations of Maxigo. For example, Falloff maps, Tiles, Gradients, Colour Correction etc.
(Sorry - it's probably a bit annoying to keep having to refer to Maxigo, but given that IndigoMax has been kicking around for nearly 6 years https://www.indigorenderer.com/forum/vi ... =9&t=11300, and there are features here and there that are missing or undeveloped compared to Maxigo, it's only fair.
The problem is that IndigoMax is the only Max exporter that fully works with Indigo 4. Maxigo does but with .igs tweaking, and the export times are horrendous. So we (or I) are tied into using IndigoMax, and then not having features that were present in its predecessor.
Given I just bought another license for my architectural practice to use Indigo with 3dsMax last week [and they were equally impressed with what it can offer], I fully support Indigo and you guys at Glare. 3dsMax and Indigo has been my workflow for the last 7 years. I know the Glare team isn't huge, but the Max exporter needs more attention and quicker development - if anything to compete with Corona and Vray.)
Re: IndigoMax 0.6.3
Post by fused » Thu Jun 29, 2017 1:18 am
Jay-ko wrote:Multi-materials and emitting properties are not linked.
Hi Jay-ko,
can you send a max scene showing the problem?
Thanks.
Re: IndigoMax 0.6.3
Post by fused » Fri Jun 30, 2017 5:53 am
OpenCL device selection should be fixed for next release.
Jay-ko
Re: IndigoMax 0.6.3
Post by Jay-ko » Fri Jul 21, 2017 2:11 am
Hey there!
Now you have everything to do the test yourself 8)
Notice that If you clikc on "Emission" in the material editor, 3ds max open the following pop-up error.
light-max.zip
(71.73 KiB) Downloaded 1762 times
tar_gniK
Re: IndigoMax 0.6.3
Post by tar_gniK » Sun Jul 23, 2017 2:04 am
^ I've managed to created the same crash in Max 2013. :roll:
Sometimes also when creating an object, Indigo/Max will crash if there is not an "Edit Mesh" modifier on top. "Vert index out of bounds".
Re: IndigoMax 0.6.3
Post by OnoSendai » Sun Jul 23, 2017 2:26 am
tar_gniK wrote:^ I've managed to created the same crash in Max 2013. :roll:
Can you send us a max scene that can replicate this crash?
tar_gniK
Re: IndigoMax 0.6.3
Post by tar_gniK » Sun Jul 23, 2017 5:22 am
Hi OnoSendai,
I have sent a PM with a link to a test file.
Users browsing this forum: Ahrefs [Bot] and 28 guests
