IndigoMax 0.3.5
ENSLAVER
Re: IndigoMax 0.3.5
Post by ENSLAVER » Sat Oct 05, 2013 8:29 pm
subpixel wrote:
ENSLAVER wrote:Suggestion: Environment map coordinates should be set to "spherical" rather than "spherical environment"
Sure, I'll make a change for standard bitmap.
Please be advised that most of functionality you're referring to should be available with Indigo Texture Map. Have you tried it? If there's a need I could add a switch for disabling map preview for it, however I cannot do it for standard bitmap.
ENSLAVER wrote:[*] Need a double-sided-thin material type.
Have you tried Indigo DoubleSided material?
The indigo texture map works great, turning off the preview before loading the HDR stops the preview so there is no need to add a switch regarding previews.
Ha, yeah I found the double-sided-thin material. I edited my post but you were too quick and quoted it first! :D
kdarius
Re: IndigoMax 0.3.5
Post by kdarius » Tue Oct 08, 2013 6:35 am
I still do not see any of the indigo materials in the slate editor. Is there somewhere i can see what version of indigomax is being used in the rendering setup or anywhere else? I want to make sure there is no conflicts.
Thank you,
Darius Kirschner
subpixel
Re: IndigoMax 0.3.5
Post by subpixel » Tue Oct 08, 2013 8:56 am
kdarius wrote:Is there somewhere i can see what version of indigomax is being used in the rendering setup or anywhere else?
Sure. Goto: Customize > Plugin-in Manager and scroll to IndigoMax.dlr in description column it should read: "Indigo Renderer for 3ds Max v.0.3.5"
Please note that material become available only if selected render engine is Indigo and they all belong to Indigo rollout.
kdarius
Re: IndigoMax 0.3.5
Post by kdarius » Tue Oct 08, 2013 9:06 am
oh ok mine says 0.3.118. How should i go about deleting this older version.
subpixel
Re: IndigoMax 0.3.5
Post by subpixel » Tue Oct 08, 2013 9:22 am
To manually remove IndigoMax do following:
1. delete <max root>\plugins\IndigoMax folder
2. delete <max root>\plugins\IndigoMax.dlr file
3. delete <max root>\scripts\IndigoMax folder
4. delete <max root>\scripts\Startup\IndigoMax.ms file
That's it. Hope it helps
kdarius
Re: IndigoMax 0.3.5
Post by kdarius » Wed Oct 09, 2013 3:06 am
That worked thank you.
Re: IndigoMax 0.3.5
Post by OnoSendai » Tue Oct 15, 2013 12:48 am
awsjolie wrote:My RT version doesn't work. It warning that my indigo license is RT and have to redownload the RT version when i hit render button although I downloaded it from "Indigo RT 3.6.23 for 3dsmax" link.
The Indigo RT version of IndigoMax works fine for me.
Can you post a screenshot of the error message?
Maybe also try uninstalling any Indigo versions you have around.
Users browsing this forum: No registered users and 144 guests
