How to set transparency ?
10 posts • Page 1 of 1
temo
Post by temo » Sat Feb 24, 2007 4:52 am
How to set the and adjust transparency to make someting half transparent ?
filippo
Post by filippo » Mon Feb 26, 2007 7:48 pm
you can turn off and turn on the trasparency whit the box option in indigo glass material, and you can set the trsparency to set the distersion and index of ref.
filippo
manitwo
Post by manitwo » Mon Feb 26, 2007 11:49 pm
if you use a 0.7 test version you could make a blend material. (for example: 50% glass + 50% diffuse)
Post by suvakas » Tue Feb 27, 2007 1:38 am
manitwo wrote:if you use a 0.7 test version you could make a blend material. (for example: 50% glass + 50% diffuse)
Doest it really work? I mean, have you tested it and can you confirm it works? The thing is, that every time i use medium material in blend, then i get sooooo messed up rendering. I thought, that blend doesn't work with medium and sss materials.
Suvakas
manitwo
Post by manitwo » Tue Feb 27, 2007 2:00 am
Suvakas
hmm ... youre right. thought it would work. sorry
Post by suvakas » Tue Feb 27, 2007 2:05 am
manitwo wrote: hmm ... youre right. thought it would work. sorry
Gotcha! No problem!
Medium/SSS in Blend could be really great. Sad that it doesn't work :cry:
Suvakas
Post by OnoSendai » Tue Feb 27, 2007 2:08 am
Yeah.. blending transparent stuff (stuff that uses a medium) probably doesn't work. will fix soon :)
neepneep
Post by neepneep » Tue Feb 27, 2007 2:11 am
^^ I thought it did work:
eg.
		<medium>
		<name>Plastic</name>
		<precedence>50</precedence>
		<basic>
			<ior>1.4</ior>
				<rgb>
					<rgb>10 10 10</rgb>
				</rgb>
			<subsurface_scattering>
					<uniform>
						<value>30</value>
					</uniform>
				<phase_function>
					<uniform/>
				</phase_function>
			</subsurface_scattering>
		</basic>
	</medium>
	<material>
		<specular>
		internal_medium_name>Plastic</internal_medium_name>
		</specular>
	</material>
	<material>
		<name>White</name>
		<diffuse>
			<colour>0.975 0.975 0.975</colour>
		</diffuse>
	</material>
	<material>
		<name>PlasticBlend</name>
		<blend>
			<a_name>White</a_name>
			<b_name>Plastic</b_name>
			<blend_factor>0.85</blend_factor>
		</blend>
	</material>
edit: but then again...I notice the scene really goes weird when using reinhard tonemapping.
Post by Kram1032 » Tue Feb 27, 2007 3:31 am
Therefore, you can use violet ;)
btw... what's with yellow?
filippo
Post by filippo » Tue Feb 27, 2007 3:31 am
indigo 0.7 for 3ds max it's ready?
filippo
