Indigo is not working with max9
9 posts • Page 1 of 1
Vancliff
Post by Vancliff » Fri Feb 09, 2007 11:55 am
I installed everything according to the tutorials, readme files and videos. put the name of the dir in the inifile but everytime i hit render it export the scene and open the picture viewport and indigo shows an error message:
"indigo.exe has detected a problem and most be closed".
I am using indigo M2I616f with 3dmax9 on athlon xp64 3.2 + 2 gig ram DDR2 on MSI 940 motherboard with n-vidia geforce 7300 pci-express 256 DDR2
surreal
Post by surreal » Fri Feb 09, 2007 12:27 pm
Are all your objects mesh's? Do they all have an indigo material? and do you have a mesh object with an emiter material?
Vancliff
Post by Vancliff » Fri Feb 09, 2007 12:55 pm
incredible that a lack of an emitter makes the error. should be an alert message for that as it is for the camera
Vancliff
Post by Vancliff » Fri Feb 09, 2007 1:00 pm
ok solved now but where is the rendering after 1 min and 52 secs I just got a black window?
Post by OnoSendai » Fri Feb 09, 2007 1:00 pm
In the most recent versions of Indigo it prints an error msg.
afecelis
Post by afecelis » Fri Feb 09, 2007 1:48 pm
you must use Indigo 0.6 official. The latest Max2Indigo only works with that version. Indigo 0.7 has a completely new material system and xml syntax for which exporters for all major 3d apps used need to be rewritten.
But many have successfully used Max9 and U3dreal's Max2Indigo. ;)
filippo
Re: Indigo is not working with max9
Post by filippo » Fri Feb 09, 2007 5:42 pm
Vancliff wrote:I installed everything according to the tutorials, readme files and videos. put the name of the dir in the inifile but everytime i hit render it export the scene and open the picture viewport and indigo shows an error message:
indigo 0.6 work very well on max9, if you have the problem, you can post it in this forum..
sorry for my language
indigo gira bene su max9,se hai dei problemi, postali qui..
filippo
Post by Kram1032 » Sat Feb 10, 2007 3:10 am
Fillipo: You don't have to be sorry: The posts of you, I read are quite correct. :wink:
(sorry for OT)
Vancliff
It works now in max9
Post by Vancliff » Fri Feb 23, 2007 9:36 am
Is working properly now and is rendering really fast
