Hi
Is there anyway that Maxigo and Indigo will support particles? Would make things heaps easier!
cheers
Particles ?
Re: Particles ?
Hey,
Do you mean Particle Flow? Particle Flow is indeed not supported at the moment.
But other types should all work:
http://www.youtube.com/watch?v=3q86ZQ_bF44
Re: Particles ?
Thanks for the replay Suvakas. I am using a pflow to create clouds. Do you know of any other way to make realistic "volumetric" looking clouds will post my vray render soon to show what I want to achive with indigo.
Cheers
Cheers
Re: Particles ?
Here is the tutorial of the clouds http://www.cgrats.com/create-realistic- ... s-max.html
Re: Particles ?
Maybe it can be done with heterogeneous participating media, but it's probably too difficult to add it in manually.
http://www.indigorenderer.com/forum/vie ... f=1&t=9629
Re: Particles ?
mmm... gona have to learn ISL then. Thanks for the info Suvakas!!!
Re: Particles ?
You can use max particles, you just have to add a mesher (create>compound>mesher) it will mesh the particles and maxigo will export them, but no moblur, not sure how well it works for animation either.
