[SOLVED] Maxigo isnt saving linked/imported materials
6 posts • Page 1 of 1
dcm
Post by dcm » Mon Jan 24, 2011 7:46 am
Hi Suv, i noticed that maxigo isnt saving linked/imported materials. It really disturbing to link/import all materials used again, especially in complex scenes every time when project is loaded :roll:
Is possible that u can check it ? Im not sure if its not working when 3ds max is closed or PC restarted (probably temp folder issue or ?) because im getting this error randomly and in all my new/older projects.
Re: Maxigo isnt waving linked/imported materials
Post by suvakas » Mon Jan 24, 2011 9:05 am
Hmm.. seems to work Ok here (I closed and re-opened Max and linked mats were Ok. Didn't restart my Pc though).
Are you sure you haven't deleted your linked material files ? Cause Maxigo never cleans the temp folder it uses for downloaded materials.
dcm
Post by dcm » Mon Jan 24, 2011 10:25 am
im checking all possible things - i will post something tomorrow. You said TEMP folder..,im using win7, maybe its deleting temp automatically or in some time period hmm
Post by suvakas » Mon Jan 24, 2011 6:43 pm
You could try to setup a new custom folder for Maxigo temporary files under Maxigo::System panel. Put it somewhere outside the standard win 7 temp folder. Just make sure it is not read only.
dcm
Post by dcm » Tue Jan 25, 2011 8:21 am
solved - temp folder issue
Re: [SOLVED] Maxigo isnt saving linked/imported materials
Post by suvakas » Tue Jan 25, 2011 8:54 am
Great !
