[REQ]UV Texture default value
- Doug Armand
Can we have the exporter automatically change/set the UV Texture name from UVTex to 'default' so it works in Indigo Material Editor without us manually having to do it each time in Blender?
Doug
Doug Armand
Doug Armand
Re: [REQ]UV Texture default value
in which cases exactly ?
what if there is more than 1 uv map on a mesh ?
It should be possible, but I need to make sure that it's implemented correctly.
- Doug Armand
Well originally I wanted the Material Editor to be able to use a UV Set other than 'default' but that didn't go down too well - see this thread:
http://www.indigorenderer.com/forum/vie ... f=5&t=7776
But you make a good point - what about multiple UV Sets?
Doug
Doug Armand
Doug Armand
OK, probably the first step that can be taken is to replace the word 'UVTex' with 'default' whenever it is encountered, either in mesh export or material export.
This way:
- any mesh with a single UV map will be exported as 'default' by default (but still be called UVTex in blender)
- any custom-named UV sets (single, first, second or otherwise) will be preserved.
It's a bit 'voodoo' IMO but should mean that any indigo-format files will conform to indigo's standards.
This way:
- Doug Armand
sounds like a good compromise - I like it.dougal2 wrote:OK, probably the first step that can be taken is to replace the word 'UVTex' with 'default' whenever it is encountered, either in mesh export or material export.
This way:
Doug
Doug Armand
Doug Armand
