For some weird reason there have been repeated errors of 'no such uv set '(whatever)', despite the fact that I have made sure that the name of the UV (which I did not change in the F9 panel- mesh tab) corresponded with the one I typed in the exporter (under UVset).
And, yes, I did unwrap the mesh
Any idea what is going on here?
Thanks in advance
Weird UVTex problem
Weird UVTex problem
DeviantArt: http://jonka5.deviantart.com/
- Doug Armand
Re: Weird UVTex problem
If your sure that both your object and Indigo are using the same UV name.... is there more than one object using the material - and do they ALL have UV's with the same name?
Doug
Doug Armand
Doug Armand
