"ghost" uv- coordinates : how to delete them ?
4 posts • Page 1 of 1
drBouvierLeduc
Post by drBouvierLeduc » Wed Nov 01, 2006 3:34 am
I've got a problem with blender and indigo :
I'm modelling a door in blender, and as you can see the render is weird in indigo.
It seems there are some "ghost" uv coordinates attached to the mesh.
I want a simple phong material, with no UV texture.
So in the XML I get the <expose_uv_set> tag, though I didn't apply any UV mapping to the mesh...
I tried to delete any reference to UV coordinates in blender, with the "TexFa --> Del" button, but it doesn't change anything.
So, do you know how to delete any reference to UV coordinates in Blender ?
Thanks for help (I already had this problem several times before, and the only solution I found was to model the mesh from scratch...)
afecelis
Post by afecelis » Wed Nov 01, 2006 4:27 am
check the material you're having the problems with in blender. Go to F6 mode and check if it's still has gotten any texture added to it; if so, hit the small "X" to delete it and your material should return to a simple color diffuse material you can use as phong.
Then set a window into "UV face select" mode and another one to "UV/image editor" and hit also the smal "X" there to get rid of the mapping info.
finally, in the top viewport hit "U" to get unwrapping options and select: "reset 1/1"
http://afecelis.gdlib.net/Indigo/uv_reset.jpg
drBouvierLeduc
Post by drBouvierLeduc » Wed Nov 01, 2006 4:48 am
Thanks for your reply.
That's what's strange : there's no texture applied to the mesh, no image selected in the "UV/image editor".
Well in blender, the mesh seems to be perfectly "clean" : it is just a basic phong material, not textured.
But I imported that mesh in blender from an old project, where there was lots of uv maps everywhere, so maybe that's the cause of the problem...
So I can remove the <uv_set> in indigo's xml, but it would take me ages to edit that xml for every single change I make...
Help !
lekane
Post by lekane » Sun Nov 19, 2006 12:52 am
In edition panel (F9) you have "Texfac" maybe this is what you are looking for.... not sure though
