Subsurface scattering
9 posts • Page 1 of 1
dembooed
Post by dembooed » Mon Apr 20, 2009 6:19 am
I try to understand SSS in Indigo/Blendigo but I can get just black material.
I ve tried to find any tutorials or examples about Subsurface scattering but without success.
Could you give me any solution or source of knowledge about SSS ?
Peace!
Meelis
Re: Subsurface scattering
Post by Meelis » Mon Apr 20, 2009 7:44 am
In blender edit mode select object & hit ctrl+n.
Or rise max depth in blendigo.
SSS is slow. I renderd 230h to 6000spp @ 1680x1050.
SmartDen
Post by SmartDen » Mon Apr 20, 2009 8:02 am
Select SPECULAR material type, don't forget to turn on 'Transparent' button(or select spec type 'glossy transparent'), select desired RGB absorption color and set RGB gain about 5, turn on 'Subsurface Scattering' and select Scatter type and Phase function. To get proper effect, the mesh should be closed (like a sphere or suzanne) and normals should be directed outwards. Don't forget to select bidir.
Check normals, dude!
dembooed
Post by dembooed » Mon Apr 20, 2009 9:01 am
It wasnt problem with normals, just with settings.
Thank You Guys!
dembooed
Post by dembooed » Mon Apr 20, 2009 9:18 am
@SmartDen: is it possible to make "blended material" with two SSS materials ?
Post by fused » Mon Apr 20, 2009 9:31 am
dembooed wrote:@SmartDen: is it possible to make "blended material" with two SSS materials ?
no, at least not with the specular material. indigo doesnt allow to blend two delta distibution materials (iirc). but, this should be possible by using two glossy transparent materials with relatively high exponent.... maybe.
edit: tested, works
edit: be aware that this is probably not recommended and that i suspect it not to be valid in the aspect of physical correctness at all :P
dembooed
Post by dembooed » Mon Apr 20, 2009 9:56 am
:) OK, thx a lot !
dembooed
Post by dembooed » Mon Apr 20, 2009 11:55 am
It's me again :)
Guys, do you have any tests of SSS's settings to see difference between combination of values ?
Peace!
SmartDen
Post by SmartDen » Mon Apr 20, 2009 8:38 pm
dembooed wrote:It's me again :)
Peace!
search in forum. there are a lot of SSS tests.
