aleksandera
by aleksandera » Sat Mar 22, 2008 11:39 pm
How do I blend more than two materials??
I remember seeing someone on the forum blending five of them.
Where did I see this, and how can I do this?
Thanks for any ansver.
Sorry for my b.a.
Regards,
Aleksander
Vanessa07
by Vanessa07 » Sun Mar 23, 2008 1:34 am
You blend blended material
You create four mat, you create two blended with these mats, then you blend your two blended
drBouvierLeduc
by drBouvierLeduc » Sun Mar 23, 2008 4:27 am
Or put in a different way (no offence vanessa !) :
- Create your 3 materials, A, B and C.
- Create a blended material, blending with A and B. Let's say its name is AB.
- Create a blended material, blending AB with C.
Hope it's clear.
aleksandera
by aleksandera » Sun Mar 23, 2008 5:27 am
Thanks Vanessa07 and drBouvierLeduc !!!
Actually I did try this before. Guess somthing else was
wrong and it make me stop.
I will try again. :oops:
Bye!
5OnIt
by 5OnIt » Thu Apr 03, 2008 4:48 am
I take it that you can't use an Emitter in a Blended material? Does anyone have a suggestion for a work around?
alex22
by alex22 » Thu Apr 03, 2008 4:56 am
What do you want to blend it with?
If you want it to mirror, make a thin (but 3D!) transparent plane in front of it. If you want alpha, thats not possible currently.
by Kram1032 » Thu Apr 03, 2008 4:57 am
Yes.
No. - or maybe yes...
You *can* use a textured emitter
If you blend that from one colour, you want to have, to an other, it would be like a blended emitter.... - though, that for sure wouldn't work in all cases...
5OnIt
by 5OnIt » Thu Apr 03, 2008 2:13 pm
OK... I found a work around. Thanks Guys!
by Kram1032 » Fri Apr 04, 2008 6:49 am
let me guess.... you made two meshes, one a bit bigger and with a blend of a null and that metal-material, and the other one, a ball of either an emitter (on) or also the metal material (off)...
I thought, you want to blend two emitters xD
5OnIt
by 5OnIt » Tue Apr 08, 2008 5:51 am
Kram1032 wrote:let me guess.... you made two meshes, one a bit bigger and with a blend of a null and that metal-material, and the other one, a ball of an emitter ...
Ummmm... Yup. And it worked just dandy.
